- Dec 1, 2004
- 397
- 2
- 18
I just found a 1969 351W block out of a Fairlane. Is this block ok to build a 408W with to put in my Mustang? Should I look for a different block? Thanks.
86bluecobra said:when you buy a stroker kit make sure you let them know it is a 69 block since the deck hieght is different.
Hickfied said:I don't think it would matter that the deck height is .02 lower... Unless the stroker kit is designed to put the piston .03 out of the hole on a 9.5 deck....
vristang said:The only other problem with the older blocks is when trying to run roller cams/lifters.
The best option is to use the tie bar aftermarket lifters.
The least attractive option would be a reduced base circle cam, and 302 roller lifters.
jason
Vipersix said:Or you could always simply drill and tap your own holes for a retaining tray (spider tray) and use roller lifters as I have done
vristang said:Using a standard base circle 302HO roller cam will push the lifters too far out of the lifter bores. The lifters will get so high that the oil holes will be exposed.
haha whatever shipping is plus 50$ LOL You would spend a fortune on shipping though! The block is freshly bored .030 over and line honed. . . i had the block given to me and really have no use for it (unless the 331 blowsHickfied said:How much Modular2v?![]()
