1970 TIMING COVER POINTER
  • Thread starter Thread starter danny clemens
  • Start date Start date Sep 9, 2007
D
danny clemens
728
  • Sep 9, 2007
I have a 1970 type aluminum timing cover for my 351W block. I'd like to put a 69 water pump on it so the bottom hose would be on the passenger side. Are there any timing pointers that would bolt on to the drivers side of the cover or would I have to make my own? If there are what would they come off of?
BullittStangV8
1,104
NJ
Sep 9, 2007
  • Sep 9, 2007
I'm looking for the exact same thing. any help would be great
D
danny clemens
728
  • Sep 10, 2007
OK BullittStangV8, it looks like it's up to you and me. I've checked a 67 Fairlane 289 and a 69 Cougar 351 and both have the cast in pointer on iron covers. I'm wanting to keep my aluminum cover and not have a cast iron one. I know where some old trucks are and I'm going to go look at them in the next few days. I'll let you know if I find something and would appreciate it if you let me know if you find anything.
jasonn
316
By Rochester MN
Sep 11, 2007
  • Sep 11, 2007
I left my old pointer on it. Very hard to see but with the hose off, I lined up the timing mark. Then I took a piece of aluminum and cut and bent it so that it would bolt to one of the timing cover bolts on the other side. My balancer is marked at 270 dg. I bent the alum. and shaped the end to more of a point. Then bolted it to the cover and I had to do a little tweaking, but got it to line up real nice. Now I can time from the other side.
D
danny clemens
728
  • Sep 11, 2007
Good tip jasonn. That's a good way to see if the other side is set correctly. If I can't find one I'll make one.
BullittStangV8
1,104
NJ
Sep 11, 2007
  • Sep 11, 2007
yea it looks like ill be trying to make one as well...What would be material/thinkness to make out out of? Its crazy that all the part shops I look at only have timing pointers for the passenger side. I have a part number for a driver side one, but they are no longer in production from ford?
D
danny clemens
728
  • Sep 11, 2007
Stainless steel would probably be the best but aluminum or mild steel would also work as long as you could bend it. It would have to be thick enough so that it wouldn't bend too easily. I would think the thickness should be at least .030" if not a little thicker. I may go with steel about 1/16" thick and weld it with the bends where I want them.
BullittStangV8
1,104
NJ
Sep 11, 2007
  • Sep 11, 2007
I wish I had a welder..
D
danny clemens
728
  • Sep 11, 2007
I've got a stick welder that I've had for a long time. When I was restoring my son's 64 1/2 about 10 or so years ago I bought a Lincoln 110 mig. I use it quite often and haven't used the stick welder since I bought the mig. I keep the stick welder just in case I have to weld something real thick but that's never happened. I love my little Lincoln.
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
