1971 Ford 302 Distributor replacement
  • Thread starter Thread starter folson
  • Start date Start date Jul 14, 2018
F
folson
35
IL
Jul 14, 2018
  • Jul 14, 2018
Well as I posted and had a lot of great replies. Going forward with replacing the distributor. Any suggestions or expert advise ?
zookeeper
3,415
63
109
Rogue River, Oregon
Aug 10, 2018
  • Aug 10, 2018
Advice on what? On what type to replace it with or how to replace it?
F
folson
35
IL
Aug 10, 2018
  • Aug 10, 2018
Hello Thank You Well basically on the replacement in whole. Ive looked at a lot of videos etc but this would be a first for me. Just concerned in getting the TDC correct. Ive seen if you mark how the old came out that works with making sure number 1 on the orientation on the distributor. I don't have any of the tools Ive seen for finding TDC. Thanks
zookeeper
3,415
63
109
Rogue River, Oregon
Aug 11, 2018
  • Aug 11, 2018
Tools? We don’t need no stinking tools! Here’s a quick method I use: pull the number 1 spark plug out. On any V8, it’s always the farthest one forward. Block the hole with your finger or thumb and have a friend “bump” the key, just a little tap at a time. When your finger is forced from the hole, you are very close. Look at the balancer and you should see the timing mark at or near TDC. Use a socket and breaker bar to bring the mark right inline with the TDC pointer. At this time the engine is at TDC. Now just remove the old distributer. To reinstall, put the rotor a little before the number one plug wire on the cap as you drop it in. It won’t go all the way in in all likelihood, so once it’s close, have that same friend tap the key and it’ll drop right in. At this time make sure the timing mark is still at TDC and the rotor is aligned with the number 1 wire on the cap. Snug the distributer down and it’s close enough to fire up. Set the timing with it running and it’s all good. If you run into problems, post them up and I’ll be glad to help. It’s easy!
F
folson
35
IL
Aug 11, 2018
  • Aug 11, 2018
Thank You! when I go for it I'll post the result... Thanks again
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Fox 5.0 Mustang Tech Wednesday at 8:21 PM
Dakar09
D
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
