1980 mustang gauges problem
redstang80
28
hello all,
I have a 1980 mustang, 4 cylinder 2.3 liter automatic. The trouble started when I started the car one day and the gauges would not work. After checking all fuses and making sure the connections were tight, I pulled the wiring harness and found a few weak connections and fixed them. I put the harness back in and still no luck. I've tried replacing the printed wiring on the back of the cluster and replacing the voltage regulator on the instrument panel with no luck at all. I was wondering if there is something I should check to see what else is wrong or if there is something I'm missing.
Thanks.
