Bulbs are good, all others work, fuse is good. Checked the wiring/plugs on the trans and they are connected and seem fine. The car does have wires tapped and "updated" under the dash and around the fuse panel. God knows what that is at this juncture and if it has anything to do with the reverse lights (Waiting to hear from the previous owner). At the back of the car, there is a little device (a box thing) that has a ground (Black) and a red leading out (What is this device?). The red wire was cut, which I re-attached to see if that did anything. Made no difference.
Anywho.....Outside of trying a new trans harness sensor.....whats the next step in the diagnostic process? Any hidden switches maybe???
Thanks y'all
Thanks y'all
