1986 GT Codes
  • Thread starter Thread starter gmartian
  • Start date Start date Jan 14, 2021
G
gmartian
11
Seekonk
Jan 14, 2021
  • Jan 14, 2021
I pulled codes today with a new computer in my 86' and got the following, 43, 63, 81, 82. I understand the 43 "Lean at WOT" as I just dropped the whole exhaust off including the 02 sensors as I thought the cats were clogged. I'm confused on how I should go about correcting codes 63, 81 and 82.
Mustang5L5
Mod Dude
Feb 18, 2001
43,321
18,048
224
Massachusetts
Jan 14, 2021
  • Jan 14, 2021
OCode 63 is TPS voltage too low. You’ll want to check voltage at idle. Needs to be between 0.5-1.25v. To trigger the code means you are below 0.5v. This code can be an old stored cold, so you might want to delete codes, then rerun them after a few drive cycles
code 81 and 82 pertain to the solenoid for the air injection system. I assume those are deleted. You can ignore these without issue.
G
gmartian
11
Seekonk
Jan 15, 2021
  • Jan 15, 2021
How can I check the voltage? Or with what kind of tool can I do such?
Mustang5L5
Mod Dude
Feb 18, 2001
43,321
18,048
224
Massachusetts
Jan 15, 2021
  • Jan 15, 2021
You’ll need a digital multimeter. Plenty of affordable ones on Amazon or Harbor frieght.
I would erase the codes and retest. Could be an old code
G
gmartian
11
Seekonk
Jan 16, 2021
  • Jan 16, 2021
Alright I'll get on that asap, thank you!
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
A
2020 Ford Mustang GT P0036, P0138, P0141 02 sensor help
  • AmkoA
  • Jul 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 5, 2025
skkrtis
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
