Electrical 1988 mustang instrument cluster.
palacios289
21
hello. New to me 88 notchback. Slowly going thru everything. Having and issue with cluster lights not turning on and insruments going crazy with headlights on. Head to firewall ground is attached properly. I do notice the tachometer needle will rise and fall based on me moving the dimmer wheel. where should I start to troubleshoot. Thanks in advance.
Hello. Original V-8 car. Its the correct cluster for a 88 Mustang. The headlight switch socket looks good too. Will a bad dimmer switch cause the tach needle moving around? Failure of cluster backlights to work? Thanks.
Sounds familiar. Here is a short thread on the issue I had with the lights in my 87. I ended up replacing the dimmer switch and the problem disappeared.
Reactions: General karthief
