1989 Gt O2 Sensor
Amador124
Hi All, so I have a 1989 Gt hatch. I've had really bad issues with car lately. When I go to accelerate, the car bogs out. It idles perfectly and let's me rev the car normal. It's only when it's moving and under load that it dies out. I have changed the EGR, IAC, MAF sensor and Air charge temp sensor. I also adjusted the timing with the spout connector off. Like i said, it idles perfectly and it will let me drive the car for a few minutes before acting up. I recently got x pipes and got new bosch o2 sensors. Yesterday when I disconnected the o2 sensors, the car ran great. It didn't hesitate at all. I drove it around a couple of miles and all seemed fine. I should also note that the muffler shop relocated my upper o2 sensors closer to the header (about a foot above where the stock placement was) Do you think this could just be a case of bad o2 sensors?
Wen you disconnect the O2 sensors, the computer goes into Limp Mode and does not depend on sensor input. Limp Mode is to just that; limp to the nearest shop to fix the problem. It uses safe settings to prevent damage to the engine. Limp Mode gives reduced performance and economy.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
Or for a nicer scanner see Equus Digital Ford Code Reader (3145) Equus - Digital Ford Code Reader 3145.
It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
Alright guys, so I think I isolated the problem. I tested the coil with a multimeter with the ground on the battery and both wires going to the coil read positive. I read somewhere that one of them (the green wire) should have a pulsating negative. What side effects can I experience with both wires reading positive?
Should both wires read positive voltage when connected to the battery? When I connect the ground to the battery and test both wires going to the coil, they both have positive voltage. Is one supposed to have negative voltage?
You are chasing the wrong rabbit, I advise you to go back and dump the codes.
Looking for an O2 sensor problem by measuring the voltage at the coil will not get you anywhere useful.
The coil wires question: the red/green wire will read 12 volts. The other wire will read a pulsing voltage when the engine is cranking..
