I've been at this for a bit. While driving, the initial time i take off and go through the gears, I have no issues. After coming to a stop, accelerating and then when accelerating through third, fourth and fifth, between 2500-3000 RPM's my car does not accelerate and tries to die. Here is what I have done so far since owning the car (I am ok with the parts so far as I am trying to restore the car). I have replaced the fuel tank, fuel sending unit, fuel pump with CJ Pony's kit at 225 lph, fuel filter (pre tank change so may be an issue), new distributor cap, distributor rotor, new plug wires, coil pack, fuel pressure regulator, TPS sensor, 02 sensors (had EEC codes for these), IAC control motor, coolant temp sensor (came with kit). I don't have a smog pump nor an EGR, there is a delete kit on. When I replaced my tank, I didn't order the sound deadening material so I can hear my fuel pump in my car when operating. While driving, and I get into the above condition, it sounds like my pump is muffled or struggling/binding as the frequency of the pump changes. I put a fuel pressure tester on the fuel rail, during initial start I get 35 psi at idle, increases as I "gun" the engine then drops to 35 psi. After driving and I get into the above condition, the fuel pressure drops to approx 10 psi and remains. Once this is observed, I can turn the car off for about 5 seconds, restart the car and it'll run normally for another trip through the gears until I come to another stop. Kind of like there is something in the fuel tank that eventually gets sucked up to the fuel pump inlet, but is very repeatable which is why I don't suspect something floating in the tank. Current KOER codes are as follows: 21R, 94R, 44R, 33R, 13R and 8. Any help would be greatly appreciated. Thanks in advance.
