Expired 1989 Mustang Gt 345whp/123,000mi/2,400mi On Engine An Trans.
Car is located in nashville, Tn.Around 2,400 miles on 347 stroker , trickflow heads, comp cam ,
bbk upper & lower intakes, 70mm bbk throttle body, injectors,adjustable fuel pressure
regulator,New msd ignition and coil, accel distributor, bbk headers, newer exhaust , New 240
amp alternator & 4ga. power wire. Tremec 5 speed maual trans with around 2,400 miles as well
and short throw shifter. Cold a/c and hot heat, pretty clean car. Dyno tuned by delk
performance, 345 whp & 385wt. check engine light out now an have dyno sheets. About 123,000 mi.
on body , paint isn't bad, poly urethane bushings, hotchkis performance struts an gas
adjutables on rear. bbk body connectors, traction bars, and 3:55 rear end gear. Low coolant
light comes on because overflow bottle is cracked an it has the sensor on top. NO TRADES, NO
paypal, NO personal checks $7000.00 OBO (615-924-5279) Leave msg. an I will get back to you
a.s.a.p. It can be seen on ebay, item # 181653956190 MAKE OFFER THANKS!
