  • 2.3L (N/A & Turbo) Tech
Fuel 1990 LX 2.3 hot no start
  • Thread starter Thread starter LA racing
  • Start date Start date Sep 25, 2024
First Prev 2 of 2
L
LA racing
15
B.C. CANADA
Sep 28, 2024
#21
  • Sep 28, 2024
  • #21
89ripper said:
This is why i was thinking you had multiple problems and not just one. Since you have 2 "motorcraft" icms, we will put that aside for now. I put it in quotes because 9 out of 10 times they arent actually motorcraft.
I was thinking the icm was getting hot and causing it to stall- that would be one problem. How many miles on this engine?
160,000 Kilometers.. 99,000 miles
89ripper
926
308
103
Rockford, Illinois
Sep 28, 2024
#22
  • Sep 28, 2024
  • #22
Ok. I originally thought that since starting fluid gets it to run, your injectors may be suspect. I understand cold starts are fine, but like i said could be compounding issues with your car. Let me look into the testing procedure for your engine.
Reactions: LA racing
AeroCoupe
6,094
4,187
183
Claremore, OK
Sep 28, 2024
#23
  • Sep 28, 2024
  • #23
If the car runs with starting fluid after it shuts off that tells me it has spark. I would suspect one of two things. Either the TFI module is overheating or the fuel pump is failing. Did you put thermal paste between the TFI module and the distributor?
L
LA racing
15
B.C. CANADA
Sep 28, 2024
#24
  • Sep 28, 2024
  • #24
Yes I put thermal paste between the TFI and the distributor.
Fuel pressure is good when the car is hot
AeroCoupe
6,094
4,187
183
Claremore, OK
Sep 29, 2024
#25
  • Sep 29, 2024
  • #25
if the fuel pressure is good hot and the injectors are firing but it won’t run and then you feed it starting fluid and it runs means no fuel.
L
LA racing
15
B.C. CANADA
Sep 29, 2024
#26
  • Sep 29, 2024
  • #26
I agree I believe it's a fuel issue as well. But I don't know what else to check or look at.
AeroCoupe
6,094
4,187
183
Claremore, OK
Sep 29, 2024
#27
  • Sep 29, 2024
  • #27
Okay, so is what I stated correct? Yes or no. Also, when it shuts down are you able to monitor fuel pressure? If so does it stay steady, slowly drop off, drop to zero immediately, or ???
When the motor quits running the fuel pump will shut off.
You could also have a failing ECU.
L
LA racing
15
B.C. CANADA
Sep 29, 2024
#28
  • Sep 29, 2024
  • #28
What you stated is correct yes.
Yes I have monitored fuel pressure when it shuts off. It jumps up a few psi when it shuts off and stays there for 3 minutes. It will then very very slowly start to move down.
AeroCoupe
6,094
4,187
183
Claremore, OK
Sep 29, 2024
#29
  • Sep 29, 2024
  • #29
Man I would suspect the ECU shutting things down. Might be time to send it off to ECU Exchange and have them go through it.
Home - ECU Exchange
ECU Exchange specializes in the re-manufacturing and repair of engine control modules.
www.theecuexchange.com
89ripper
926
308
103
Rockford, Illinois
Sep 29, 2024
#30
  • Sep 29, 2024
  • #30
ICM lol....been a long week workin on gms.
Do what aero says and consider an ecu exchange, its fixed a lot of the issues that i had with my car.
L
LA racing
15
B.C. CANADA
Sep 29, 2024
#31
  • Sep 29, 2024
  • #31
Home - ECU Exchange
I have a few guys locally that have some good ICM's that I'll check out..
I have opened it up and it looked like newer unit. All the caps looked great.
AeroCoupe
6,094
4,187
183
Claremore, OK
Sep 29, 2024
#32
  • Sep 29, 2024
  • #32
The ones they have are 30+ years old as well. It’s not just the caps they replace. Just send it and then you will know for sure it’s in good shape.
First Prev 2 of 2
J
1990 fox starts on starting fluid only
  • Jfox
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 15, 2026
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
