Hello , this is my first post as a member and the only spot I could even figure out how to start typing
. Anyways I am having difficulty's trying to figure out exactly what I need for my 1992 mustang 302 crate motor(M-6007-XB3) with twin t3 turbo setup so I dont screw my engine up . I need technical help with what air/fuel setup I need . I currently have 160psi in tank fuel pump , BBK fuel regulator , 70MM BBK throttle body , 75MM mass air , 30lbs injectors , and plan on 8lbs boost since ford performance said I would blow the motor if over 12lbs boost . PLEASE HELP !!!! Thank you
