2013 Mustang GT Procharger Stage 2 Kit Issues
Looking for some help/suggestions with how to diagnose some issues I am having with my 2013 mustang GT and the procharger stage 2 kit that I installed last weeked.
I ended up getting the complete stage 2 kit from procharger and have been trying to figure out if I have a boost leak somewhere. I have gone thru two tune revisions with procharger, the first was to solve a DTC for the o2 sensors detecing a rich condition. Procharger was able to make some edits to the fueling and got that squared away. Now, just yesterday I got a DTC P0507 for idle air control system rpm higher than expected. The provided tune from procharger has the idle set at 750rpm but when coming to a stop, the idle would jump up to about 850-900rpm and then surge to about 1100rpm. Procharger provided another tune revision which I have yet to try but, could this issue also be coming from a vacuum/boost leak?
Any suggestions/help would be awesome.
There is an "Idle Relearn Procedure" from BAMA tunes that may help.
This is a hybrid method based on what works in practice on Fords of similar era. Use at your own risk; “relearns” can vary by calibration or PCM version.
— Preconditions —
• Good battery, healthy charging system
• Throttle body and IAC (or equivalent) clean
• No active faults (check engine light off)
• All accessories off (radio, lights, blower, etc.)
Procedure:
1. Start engine; leave it to idle (in Park or Neutral) until it reaches **full operating temperature** (coolant temp stable).
2. Let it idle for about **1 minute** with **A/C off** and no extra loads.
3. Turn the **A/C on**, but leave blower low or as usual, let it idle for **another minute**.
4. Drive the car **under light load** (no heavy throttle) for some miles (5-10 mi or so) to let the PCM adjust fuel trims, adaptives, idle targets, etc.
5. Optionally, you can shut engine off, wait a bit, restart, and observe idle. If idle is still unstable, repeat steps above.
If you have a scan tool that supports “Throttle Body or Idle Learn / Relearn” functions, use that after battery disconnection or when replacing throttle body / sensors.
Just a little update. I adjusted some of the intercooler piping and couplers from the discharge pipe on the blower and I think I may have had a slight boost leak. I did the idle relearn procedure while datalogging and after doing a WOT pull the idle seems to have sorted itself out.
Hopefully procharger can review the log today and provide some feedback too but, thanks again for the idle relearn suggestion!
Reactions: gkomo
