1993 Cobra Mustang Hates Me .....sos .. Help ..sos ..help
  • Thread starter Thread starter 1993cobra5.0
  • Start date Start date Jan 24, 2015
  • 3
  • 4
  • 5
  • 6
First Prev 3 of 6 Next Last
Mstng93SSP
You have a nice rear end there Dave.
3,500
184
Mililani, Hawaii
Jan 26, 2015
#41
  • Jan 26, 2015
  • #41
I am also betting you have a major vacuum leak. Just went through this myself. What lower intake gasket did you use. For a cobra you can't use a standard 5.0 intake gasket. It will leak. A LOT. You need a felpro 1250 or similar gasket set that is specific for the heads/intake of a cobra/gt40 head.
Reactions: 1993cobra5.0
1993cobra5.0
66
N C
Jan 26, 2015
#42
  • Jan 26, 2015
  • #42
Wouldn't I hear a big vacuum leak. I had it running , but back firing last week and that's when I started throw new parts and checking things out .
1993cobra5.0
66
N C
Jan 26, 2015
#43
  • Jan 26, 2015
  • #43
Ms 95952.
1993-95 mustang cobra gasket set
Mustang5L5
Mod Dude
Feb 18, 2001
43,260
17,945
224
Massachusetts
Jan 26, 2015
#44
  • Jan 26, 2015
  • #44
1993cobra5.0 said:
After market one . The car comes stock with 24 lb injectors , right ?
Yes, but OEM setups don't use a "calibrated MAF" that's purely an aftermarket way to trick the computer so that you can use different injector sizes. The proper way to change size is with a tune or through the computer.
The Cobra uses programming in it's EEC to run the 24's with a special meter (as in not the same meter as the standard 5.0 HO"
You basically cannot run an aftermarketr MAF calibrated for 24's on the car because both the MAF, AND the computer are telling the car it has 24# injectors.
I would try and find an OEM 1993 Cobra 70mm MAF.
TOOLOW91
20+ Year Stangneter
8,709
234
S.I.NY
Jan 26, 2015
#45
  • Jan 26, 2015
  • #45
No it won't run as your describing only maybe with your foot on it to keep it running
1993cobra5.0
66
N C
Jan 26, 2015
#46
  • Jan 26, 2015
  • #46
Before I changed the intake gaskets , that's what I had to do to keep it running
1993cobra5.0
66
N C
Jan 26, 2015
#47
  • Jan 26, 2015
  • #47
This car hates be , it is only getting worse any thing I work on it . Well I ordered the new fuel psi gauge . If fuel is good . Nd if i can't find a vaccum leak . I will buy a new maf . That maf had been on the car for 6 years . And ran great on the car . The lasted owner b4 me installed it . It's a 70 mm
1993cobra5.0
66
N C
Jan 26, 2015
#48
  • Jan 26, 2015
  • #48
If I need to remove the intake again . I'm going to buy a new one . How's the. Trick flow track and heat
Mustang5L5
Mod Dude
Feb 18, 2001
43,260
17,945
224
Massachusetts
Jan 26, 2015
#49
  • Jan 26, 2015
  • #49
Then there's probably a chip, or a different computer in that car. You may want to investigate that further.
Also, what codes were present when you ran them? Did you run them?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,357
208
114
Ohio
Jan 26, 2015
#50
  • Jan 26, 2015
  • #50
That just doesn't sound right as the Stock Meter would have been 70mm, why would the previous owner swap it out for another 70mm. You should do as said above and do a little investigating on that.
TOOLOW91
20+ Year Stangneter
8,709
234
S.I.NY
Jan 26, 2015
#51
  • Jan 26, 2015
  • #51
If you don't mind me asking what's your mechanical back round ?
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Jan 26, 2015
#52
  • Jan 26, 2015
  • #52
He said it ran good for 5 years with the same maf he has now. I don't think it's a maf/tuing problem unless that is the maf he has crapped out. I've had stock maf's go bad, when they do the car will start and kinda choke, stumble, and die. Tell us the codes that you got when u ran codes? What are the numbers?
TOOLOW91
20+ Year Stangneter
8,709
234
S.I.NY
Jan 26, 2015
#53
  • Jan 26, 2015
  • #53
The Prob is its not as simple as tbat now because he touched so much stuff at this point it just sounds like a big vac leak
Reactions: A5literMan
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 26, 2015
#54
  • Jan 26, 2015
  • #54
Oh I hear ya. I'd rule out the maf deal though. Did he ever say what codes? Is it time for the soapy water test?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,357
208
114
Ohio
Jan 27, 2015
#55
  • Jan 27, 2015
  • #55
I was hoping he dumped the codes too.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 27, 2015
#56
  • Jan 27, 2015
  • #56
He said he did but never reported what they were.
@1993cobra5.0 How bout some codes Maddog?
1993cobra5.0
66
N C
Jan 27, 2015
#57
  • Jan 27, 2015
  • #57
The computer is stock .ford . No chip . I opened it up . Looks good inside .
1993cobra5.0
66
N C
Jan 27, 2015
#58
  • Jan 27, 2015
  • #58
Maybe it's bigger . How can I put some pix up here for you guys to see the MAF
1993cobra5.0
66
N C
Jan 27, 2015
#59
  • Jan 27, 2015
  • #59
Oh boy , I restore 60's camaros and work on a lot of 1985 to 92 TPI bodies
I've done many 4 to v8 swaps on mustang . I rebuilt my 1987 GT and 85 GT from the ground up .
1993cobra5.0
66
N C
Jan 27, 2015
#60
  • Jan 27, 2015
  • #60
I'm going to check for codes today
  • 3
  • 4
  • 5
  • 6
For Sale 1993 Mustang SVT Cobra - Black - 5 Speed - 88k Miles - Single Owner
  • Buddy Jake
  • Jun 16, 2026
Fox Body Mustangs For Sale (1979-93) Jun 20, 2026
Habu135
9
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
CJ Customer Rich's 1993 Fox Body Mustang GT Build
  • CJPonyParts
  • Aug 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 7, 2025
C
1993 airbag module noise
  • Charlie1
  • Sep 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2025
Charlie1
C
