Engine 1993 Engine Codes
  • Thread starter Thread starter Sconnell80
  • Start date Start date Sep 5, 2018
1 of 2 Next Last
Sconnell80
53
Western NY
Sep 5, 2018
  • Sep 5, 2018
Ok so I’ve run the car around town for a few days and have dumped the codes a few times to see what comes up and stays. KOEO codes are 67, 81, 85. Memory codes are 33, 41, and 91. KOER codes are 3, 92, and 33. I’m not worried about the egr or smog related codes as they have been removed from the car before me buying it. I will put resistors in to try and trick the ecm. So am I looking at both o2 sensors causing issues?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 5, 2018
  • Sep 5, 2018
Codes 41/91 and 92 are where you need to concentrate your efforts.
Code 67 You are probably the primary cause for this code...
Revised 18-Mar-2017 to include warning about the necessity of having a 5 speed O2 Sensor wiring harness when bypassing the wiring for test purposes
Cause of problem:
Clutch not depressed (5 speed) or car not in neutral (5 speed and auto) or not in park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. This code will prevent you from running the Key On Engine On tests.
External evidence from other sources claims that a code 67 can cause an idle surge condition. Do try to find and fix any issues with the switch and wiring if you get a code 67.
What the NSS (Neutral Safety Switch) does:
5 speed transmission: It has no connection with the starter, and the engine can be cranked without it being connected.
Auto transmission: It is the safety interlock that prevents the starter from cranking the engine with the transmission in gear.
What it does for both 5 speed and auto transmission cars:
The computer wants to make sure the A/C is off due to the added load on the engine for the engine running computer diagnostic tests. It also checks to see that the transmission is in Neutral (5 speed and auto transmission) and the clutch depressed (T5, T56, Tremec 3550 & TKO)). This prevents the diagnostics from being run when the car is driven. Key On Engine Running test mode takes the throttle control away from the driver for several tests. This could prove hazardous if the computer was jumpered into test mode and then driven.
The following is for 5 speed cars only. Do not do this unless you are sure that you have a 5 speed O2 Sensor harness!!!! Smoke, sparks and expensive pain in the wallet may ensue if you don’t.
The NSS code 67 can be bypassed for testing. You will need to temporarily ground computer pin 30 to the chassis. Computer pin 30 uses a Lt blue/yellow wire. Remove the passenger side kick panel and then remove the plastic cover from the computer wiring connector. Use a safety pin to probe the connector from the rear. Jumper the safety pin to the ground near the computer.
Be sure to remove the jumper BEFORE attempting to drive the car!!!
Code 81 – Secondary Air Injection Diverter Solenoid failure AM2. The solenoid valve located on the back side of the passenger side wheel well is not functional. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Lt Green/Black wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the LT Green/Black wire for the solenoid valve.
With the with the ignition on, look for 12 volts on the red wire on the solenoid connector. No 12 volts and you have wiring problems.
With the engine running, stick a safety pin in the LT Green/Black wire for the solenoid valve & ground it. That should turn the solenoid on and cause air to flow out the port that goes to the pipe connected to the cats. If it doesn't, the valve is bad. If it does cause the airflow to switch, the computer or wiring going to the computer is not signaling the solenoid valve to open.
Putting the computer into self test mode will cause the solenoid valve to toggle. If you listen carefully, you may hear it change states.
Code 85 CANP solenoid - The Carbon Canister solenoid is inoperative or missing.
Revised 11 –Jan_2015 to add warning about vacuum leaks due to deteriorated hose or missing caps on vacuum lines when the solenoid is removed.
Check vacuum lines for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always energized any time the ignition switch is in the run position.
If you disconnected the carbon canister and failed to properly cap the vacuum line coming from under the upper intake manifold, you will have problems. You will also have problems if the remaining hose coming from under the upper intake manifold or caps for the vacuum line are sucking air.
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel. The canister is normally mounted on the passenger side frame rail near the smog pump pulley.
Connecting the gas tank vent line directly to the intake manifold will result in fuel vapor being constantly sucked into the intake manifold. There is unmetered fuel that the computer cannot adjust for. The result is poor idle and poor fuel economy.
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
The purge valve solenoid connector is a dangling wire that is near the ECT sensor and oil filler on the passenger side rocker cover. The actual solenoid valve is down next to the carbon canister. There is about 12"-16" of wire that runs parallel to the canister vent hose that comes off the bottom side of the upper intake manifold. That hose connects one port of the solenoid valve; the other port connects to the carbon canister.
The purge valve solenoid should be available at your local auto parts store.
Purge valve solenoid:
The carbon canister is normally mounted on the passenger side frame rail near the smog pump pulley.
Carbon Canister:
Code 33 - Insufficient EGR flow detected.
Look for vacuum leaks, cracked vacuum lines, failed EGR vacuum regulator. Check to see if you have 10” of vacuum at the EGR vacuum connection coming from the intake manifold. Look for electrical signal at the vacuum regulator solenoid valves located on the rear of the passenger side wheel well. Using a test light across the electrical connector, it should flicker as the electrical signal changes. Remember that the computer does not source any power, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
Check for resistance between the brown/lt green wire on the EGR sensor and pin 27 on the computer: you should have less than 1.5 ohm.
Backside view of the computer wiring connector:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
EGR test procedure courtesy of cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve or see the EGR test jig drawing below. Connect the test jig or to directly to manifold vacuum.
Do not connect the EGR test jig to the EVR (Electronic Vacuum Regulator).
apply 5in vacuum to the valve. Using the test jig, use your finger to vary the vacuum
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect EGR test jig to the hose coming off of the EGR Valve.
Use your finger to cap the open port on the vacuum tee.
snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
did the vacuum gauge show about 2-5 in vacuum?
if not the EVR has failed
EGR test jig
The operation of the EGR vacuum regulator can be checked by using a test light applied across the wiring connector. Jumper the computer into self test mode and turn the key on but do not start the engine. You will hear all the actuators (including the EVR vacuum regulator) cycle. Watch for the light to flicker: that means the computer has signaled the EGR vacuum regulator successfully.
Code 41 or 91. Or 43 Three digit code 172 or 176 - O2 sensor indicates system lean. Look for a vacuum leak or failing O2 sensor.
Revised 24 Aug 2018
1.) To correct the RH & LH mismatch on 91-93 5.0 Mustangs
2.) To add Tmoss’ wiring diagrams for 88-95 Mustangs
Code 41 is the passenger side sensor, as viewed from the driver's seat.
Code 91 is the driver side sensor, as viewed from the driver's seat.
Code 172 is the passenger side sensor as viewed from the driver's seat.
Code 176 is the driver side sensor, as viewed from the driver's seat.
Code 43 is not side specific according to the Probst Ford Fuel injection book.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Testing the O2 sensors 87-93 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear.
Disconnect the O2 sensor from the harness and use the body side O2 sensor harness as the starting point for testing. Do not measure the resistance of the O2 sensor, you may damage it. Resistance measurements for the O2 sensor harness are made with one meter lead on the O2 sensor harness and the other meter lead on the computer wire or pin for the O2 sensor.
Computer wiring harness connector, computer side.
87-90 5.0 Mustangs:
Computer pin 43 Dark blue/Lt green – LH O2 sensor
Computer pin 29 Dark Green/Pink – RH O2 sensor
The computer pins are 29 (RH O2 with a dark green/pink wire) and 43 (LH O2 with a dark blue/lt green wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
91-93 5.0 Mustangs:
Computer pin 43 Red/Black – LH O2 sensor
Computer pin 29 Gray/Lt blue – RH O2 sensor
The computer pins are 29 (RH O2 with a Gray/Lt blue wire) and 43 (LH O2 with a Red/Black wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
94-95 5.0 Mustangs; note that the 94-95 uses a 4 wire O2 sensor.
The computer pins are 29 (LH O2 with a red/black wire) and 27 (RH O2 with a gray/lt blue wire). Use pin 32 (gray/red wire) to ground the voltmeter. . The O2 sensor voltage should switch between .2-.9 volt at idle.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer. Using the Low Ohms range (usually 200 Ohms) you should see less than 1.5 Ohms.
87-90 5.0 Mustangs:
Disconnect the connector from the O2 sensor and measure the resistance:
From the Dark blue/Lt green wire in the LH O2 sensor harness and the Dark blue/Lt green wire on the computer pin 43
From the Dark Green/Pink wire on the RH O2 sensor harness and the Dark Green/Pink wire on the computer pin 29
91-93 5.0 Mustangs:
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 43
From the Gray/Lt blue wire on the RH O2 sensor harness and the Gray/Lt blue wire on the computer pin 29
94-95 5.0 Mustangs:
Computer pin 29 Red/Black – LH O2 sensor
Computer pin 27 Gray/Lt blue – RH O2 sensor
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 29
From the Dark Green/Pink Gray/Lt blue wire on the RH O2 sensor harness and the Gray/Lt blue wire on the computer pin 27
There is a connector between the body harness and the O2 sensor harness. Make sure the connectors are mated together, the contacts and wiring are not damaged, and the contacts are clean and not coated with oil.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
Check the fuel pressure – the fuel pressure is 37-41 PSI with the vacuum disconnected and the engine idling. Fuel pressure out of range can cause the 41 & 91 codes together. It will not cause a single code, only both codes together.
Make sure you have the proper 3 wire O2 sensors. Only the 4 cylinder cars used a 4 wire sensor, which is not compatible with the V8 wiring harness. The exception is that the 94-95 uses a 4 wire O2 sensor.
Replace the O2 sensors in pairs if replacement is indicated. If one is weak or bad, the other one probably isn't far behind.
Code 41 can also be due to carbon plugging the driver’s side Thermactor air crossover tube on the back of the engine. The tube fills up with carbon and does not pass air to the driver’s side head ports. This puts an excess amount of air in the passenger side exhaust and can set the code 41. Remove the tube and clean it out so that both sides get good airflow: this may be more difficult than it sounds. You need something like a mini rotor-rooter to do the job because of the curves in the tube. Something like the outer spiral jacket of a flexible push-pull cable may be the thing that does the trick.
If you get only code 41 and have changed the sensor, look for vacuum leaks. This is especially true if you are having idle problems. The small plastic tubing is very brittle after many years of the heating it receives. Replace the tubing and check the PVC and the hoses connected to it.
Complete computer, actuator & sensor wiring diagram for 94-95 Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 88-90 Mass Air Mustangs
The code 3 is an oddity that pops up from time to time, normal for a 86-95 EFI Mustang is 4. The code is supposed to indicate how many cylinders the computer is supposed to support; V8's post a 4 and V6's post 3
Code 42 & 92 & 137 & 173 (engine running) System rich - Fuel control or (memory) System was rich for 15 seconds or more (no HO2S switching) - Fuel control. Look for leaking injectors, fuel pressure too high, cylinder(s) not firing due to bad ignition.
Code 42 passenger side sensor, as viewed from the driver's seat
Code 92 is the driver side sensor, as viewed from the driver's seat..
87-90 5.0 Mustangs:
The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
91-93 5.0 Mustangs:
The computer pins are 29 (LH O2 with a Gray/Lt blue wire) and 43 (RH O2 with a Red/Black wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Testing the O2 sensors 94-95 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a red/black wire) and 27 (RH O2 with a gray/lt blue wire). Use pin 32 (gray/red wire) to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
There is a fuse link for the O2 sensor heater power. According to Ranchero50, it is in the wiring near the passenger side hood hinge. Measuring the voltages will give a clue if it has shorted to the O2 sensor signal lead. The O2 sensor voltage should switch between .2-.9 volt at idle.
Removing the pollution control equipment from a 5.0 Mustang is a bad idea. All you have accomplished is to make the computer mad and spit codes. The pollution control equipment all shuts off at wide open throttle, so the HP losses from it on the car are 2-5 HP. The catalytic converters may soak a few more HP than that. None of the pollution control equipment reduces the HP enough to cost you a race in anything but professional drag strip competition. I seriously doubt that you will be in the final runoff on “Pinks”, so leave the smog equipment in place and make sure it is working correctly.
Know what does what before removing it. Remove or disable the wrong thing and the computer sets the check engine light and runs in "limp mode". Limp mode means reduced power and fuel economy.
If you removed the smog pump and still have catalytic converters, they will ultimately clog and fail.
Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by James Probst :ISBN 0-8376-0301-3.
It's about $20-$45 from Borders.com see http://www.amazon.com/ . Select books and then select search. Use the ISBN number (without dashes or spaces) to do a search
Use the ISBN number and your local library can get you a loaner copy for free. Only thing is you are limited to keeping the book for two weeks. It is very good, and I found it to be very helpful.
Remove any of the equipment and you will not pass a full smog check, cannot title the car in an area that does smog checks and have broken several federal laws. Granted that the Feds are short on people to check cars, but it is still Federal law.
"Why should I leave the smog equipment on if I live in an area that doesn't do smog inspections?"
What's good sauce for the goose is good sauce for the gander. I lived in Florida and had two smog pumps fail on two different 89 5.0 Mustangs. I replaced both of them, even though there was no emissions inspection. Why?
1.) It a federal law that requires emissions equipment to be in place and functional. I have no intention of breaking a law designed to protect my general health and wellbeing, even if I don't like it. I have respect for the rights and wellbeing of other people, and am not one of those whose nature is rebellion.
2.) Whatever imaginary "improvements" someone may strive for, there is very little evidence that the results of removing emissions results in a better car. I can achieve excellent results in performance with all the smog equipment in place and working properly. Maybe you can't, but that is no excuse for removing the emissions equipment. Look at the new 5.0 Mustangs – 281 cubic inches and 400+ flywheel HP with full emissions equipment with no aftermarket parts. That tells me that it is possible on a mass production car. It also shows that the guys that designed the engine knew what they were doing to achieve that goal.
3.) I like to breathe clean air, and working emissions equipment helps me do my part to make that possible. Los Angeles has breathable air even with millions of cars: Beijing, the capitol of China has some of the worst air in the world. Why – no emissions requirements for cars.
I don’t want to live where the air looks like this…
See http://www.taipeitimes.com/News/feat/archives/2014/01/15/2003581312
Sconnell80
53
Western NY
Sep 5, 2018
  • Sep 5, 2018
Well I changed out the o2 sensors with new ones and the initial test drive showed a whole different car. It idled better, ran better, and throttle response was better. I won’t know till I do a few cycles with the car and see if it throws a light or what comes up. I will change the fuel pressure regulator this weekend when I have more time. Probably doesn’t need it but for the price I don’t mind having new parts and knowing wen they have been changed.
Sconnell80
53
Western NY
Sep 17, 2018
  • Sep 17, 2018
Well the car seems to run better, no spitting and sputtering but it doesn’t seem to have the hard pull it used to. It pulls hard but not as hard, even my wife said it, so I know it’s not all me. I ran the KOER codes again and I still am getting 41 and 91 even with new o2 sensors. Maybe I need to look into a new o2 sensor harness or check for damage to the wire or connectors. Just don’t know why new sensors would make it run the way it should but cut back on power. Also when I run KOEO I have only seen code 11 come up maybe twice on my actron CP9690.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Sep 17, 2018
  • Sep 17, 2018
Code 41/91 doesn't necessarily mean it's the sensor or harness issue.
Those are lean codes. If replacing the sensor didn't solve the issue, then there's a strong possibility there's either an exhaust leak upstream of the sensor, or a very large vacuum leak somewhere in the system allowing air to get into the cylinder from a source other than the MAF (therefore leaning out the A/F mix).
I think you should be searching for a vac leak at this point.
What mods are on the car? Any work to it recently?
Sconnell80
53
Western NY
Sep 17, 2018
  • Sep 17, 2018
Well the car was someone else’s project so I’ve tried to get it all back together and running again. Stock bottom end, gt40p heads, gt40p lower and upper non egr. Bbk air intake with filter in fender. Smog pump, and egr deleted. Bbk maf with 24lb injectors, with bbk 65mm throttle body. 3G alternator. Cat delete pipes with H pipe and flow masters. Think that’s about it maybe forgetting a thing or two. Thing is it doesn’t act like there’s a vacuum leak anywhere as it idles good on start and runs good.
Sconnell80
53
Western NY
Sep 17, 2018
  • Sep 17, 2018
Also took off the upper intake off to replace the fpr and painted it. Has bbk shorty headers
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Sep 17, 2018
  • Sep 17, 2018
CM 41/91 is likely related to KOEO 81 and 85 and ER/CM 33. Check the TAB/TAD circuit and make repairs as necessary. Check the vacuum lines and repair/replace as necessary.
CM 41/91 does not mean "HEGO sensors bad. Replace them."
Sconnell80
53
Western NY
Sep 17, 2018
  • Sep 17, 2018
Well those solenoids are there but not hooked up as all the smog pump and tubing was removed
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Sep 17, 2018
#10
  • Sep 17, 2018
  • #10
LOL okay then that is likely why you're (still) getting 41/91
Sconnell80
53
Western NY
Sep 17, 2018
#11
  • Sep 17, 2018
  • #11
Maybe I’ll see if resistors will truck it like they do with the egr. Just can’t figure out why the old o2 sensors tripped the check engine light but pulled harder and the new sensors don’t trip the light but the car runs better just doesn’t pull like it used too. And would those codes be the reason why I’m not seeing a code 11 on my scanner all the time?
Sconnell80
53
Western NY
Sep 17, 2018
#12
  • Sep 17, 2018
  • #12
Maybe I’ll see if resistors will truck it like they do with the egr. Just can’t figure out why the old o2 sensors tripped the check engine light but pulled harder and the new sensors don’t trip the light but run
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Sep 17, 2018
#13
  • Sep 17, 2018
  • #13
If codes are not on all the time then they're "intermittent" which means they may or may not be present at any particular time you check for them during KOEO or ER.
If you are going to try to "trick" the ECM with bypass plug-ins, resistors, etc. then you may as well not even bother checking for codes and troubleshooting them. Be happy with how lousy the engine runs and eats fuel because you don't want "smog" parts on your car.
Sconnell80
53
Western NY
Sep 17, 2018
#14
  • Sep 17, 2018
  • #14
Wow nice reply, first I didn’t remove the smog parts like I said before if you read they were removed before I got the car I’m trying to get it back to running order. It’s not like you can just get these smog parts anymore that are in good condition to even use, or not cost an arm and leg. Thanks for the reply though
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Sep 17, 2018
#15
  • Sep 17, 2018
  • #15
So how much time and money are you spending to replace sensors that don't need replacing, and parts to "trick" the ECM into thinking sensors voltages are what they're not?
Sconnell80
53
Western NY
Sep 17, 2018
#16
  • Sep 17, 2018
  • #16
I’ve only replaced the o2 sensors cause I was getting lean and Rich codes plus they were factory ford sensors probably from 93. Other than that everything else was done before I bought it like I said. I would put the smog stuff back on if I could find the parts but these fox body’s are almost extinct where I’m at. I’m just asking questions learning the way these cars work. Plus I like working on cars so my time isn’t nothing.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Sep 17, 2018
#17
  • Sep 17, 2018
  • #17
Code 92 is a rich code that came up during the engine running tests, but you have a code 91 (lean) stored. So my question is which one is it? Or is it fluctuating.
I'd erase all codes (unhook battery for 30 min) and then hook it up, go for a quick ride, and rerun them again and see what you get. I still suspect vac leaks, as often times when guys rip all the smog stuff out, they inadvertently leave vac lines open and leaking, especially the ones related to the smog pump. It's not so much removing the solenoids that's the issue...it's how they were removed. There are methods to remove all the smog stuff, but it needs to be done in a certain way to avoid issues with how the engine runs. However, I've run across some hack cars in my time where all the smog stuff was yanked and they still ran strong...they just idled like absolute crap.
I'd still grab a can of carb cleaner and start spraying looking for a vac leak, especially where the lower intake seats on the heads. Wouldn't be the first time a gasket slipped, or blew apart causing an internal leak that makes the car run poorly. You stated you had the upper intake off recently. Did the issues start after that?
Sconnell80
53
Western NY
Sep 17, 2018
#18
  • Sep 17, 2018
  • #18
No they have been there since I’ve gotten the car up and running, I had both 41, 91, and 92 on the same KOER test. I replaced the o2 sensors which helped the stutter it had and the cel hasn’t come back on. I’ve had the battery unhooked this weekend when I changed out the starter that crapped out on me. I’ll dump codes again, do a heat cycle and pull them again to double check.
Sconnell80
53
Western NY
Sep 17, 2018
#19
  • Sep 17, 2018
  • #19
I also sprayed starting fluid around the upper and lower intake, around the throttle body and other vacuum lines to see if I could get a change in idle and I didn’t get any change. I also changed out the old lines for new lines and made sure the extra lines on the gt40p were capped off.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 17, 2018
#20
  • Sep 17, 2018
  • #20
Go back and re-read my first post. Everything you need to test the O2 sensors is in there...
1 of 2 Next Last
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Engine Ran my code reader and
  • Mindseye007
  • Aug 10, 2024
Fox 5.0 Mustang Tech Aug 19, 2024
Mindseye007
C
Engine Code 94 and 13
  • CmdrDerp
  • Nov 3, 2024
Fox 5.0 Mustang Tech Nov 4, 2024
AeroCoupe
P
CEL light on and Can't pull KOER codes.
  • psfoxstang
  • May 7, 2024
Fox 5.0 Mustang Tech Jun 20, 2024
psfoxstang
P
