  • SVT Tech Forum
1999 cobra gear
  • Thread starter Thread starter i3adidas
  • Start date Start date Feb 1, 2009
I
i3adidas
9
Joliet il
Feb 1, 2009
  • Feb 1, 2009
i know i've asked this question before but im getting ready to put a gear in my car. should i go with a 4:10 or pro 5.0 3:90 i dont take it to the drag i just drive it around town. everyone is telling me with a 4:10 ill just smoke my tire the other thing is i have 18inch rims on the car i dont know if that makes any diff. any has anyone use pro5.0 gear or should i stick with ford racing thanks
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Feb 1, 2009
  • Feb 1, 2009
My advice is to drive someone else's "geared" cobra, if possible, and then decide.
Will 1st gear "smoke" your tires after a gear swap? Maybe. Depends how aggressively you pedal it. Will 1st gear seem "really short?" Possibly. That's the idea of gear/torque multiplication though (when you change out a "tall" ratio for a "shorter" ratio, like going from 3.27 to 4.10 or 4.30, etc).
Try reading this, here is a direct quote of what Lidio from Alternative Auto recommends (a nice summary, IMHO):
Taken from: 4.6L Mustang Tech Q & A
"...What rear differential gear do you recommend?...
...4V Cobra: The Cobra has an entirely different engine than most people are used to. It performs best at high rpms, upwards of 7000. It's power band is relatively high due to the deep breathing nature of the two intake valves. When gearing a Cobra, 3.73's just aren't enough. They don't allow the engine to reach its powerband quickly enough. 4.10 gears are an excellent choice and 4.30's are even better. This may sound very steep if you're used to the average 5.0 which needs to be shifted by 5600 rpm. But since this engine will easily rev to 7000 it needs the extra gear and it likes it. 4.30's are our #1 choice, naturally aspirated or supercharged. At 80 mph in fifth with 4.10's the engine only turns about 2700 rpm, completely tolerable...."
As far as selecting a rear end gear manufacturer, pick whoever you want - there are many choices; Ford Racing, Richmond, Motive, etc, etc. However, I would be more concerned about who is doing the actual installation and whether or not they install it correctly. It's nice if your installer has handled an IRS gear swap before (or possibly risk paying more in labor charges). You want to make sure your installer gets the install right the first time, so you don't run into driveline vibrations, blacklash, chatter, and/or gear runout problems, etc.
Every now and then you will hear somebody complain about a particular rear end gear manufacturer but usually it's because their installer messed up the install.
FWIW, most folks will recommend Ford Racing gears...
YMMV
Bl4ckedOutC0bra
  • Feb 2, 2009
If you're not considering a blower or turbo -- GET THE 4:10's!!!
-Aaron
21MsclCr
49
Plano, Texas
Feb 18, 2009
  • Feb 18, 2009
Go with the 4.10's. Everybody I know loves them. It pulls harder and feels great. You could also go with 3.73's but my suggestion is 4.10's
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
  • SVT Tech Forum
