1999 Cobra plugs
1999redcobra
38
Ok so I have a cylinder 5 misfire so I need new plugs im guessing. So i was thinking of getting NGK irridium so I looked on ebay and this is all i could find.
http://cgi.ebay.com/ebaymotors/03-04-FORD-MUSTANG-COBRA-NGK-IRIDIUM-IX-SPARK-PLUGS_W0QQcmdZViewItemQQcategoryZ33693QQihZ017QQitemZ270155846238QQrdZ1QQsspagenameZWDVW
I dont know they say they are for 03-04 cobras would they work on my 99 or what and where should i go to find good plugs?
It's probably more likely that your misfire is the result of could be a faulty coil pack, not the sparkplug. When was the last time you changed the sparkplugs?
It would probably be a good idea to change the plugs (at least inspect them).
I'm personally not a fan of the fancy overpriced sparkplugs out there on the market. I'd rather spend my money on other mods. Nothing wrong with using a regular 'ol copper sparkplug. YMMV
G'luck with the misfire problem. :cheers:
I dont know when the plugs where changed last I bought the car may of last year and the misfire light came on when the car was in storage this year i dont drive it that much so i havent done anything but now i just want to get it fixed
The only brands I would consider are NGK or Motorcraft and I generally prefer copper but right now I am trying out a fine electrode platinum Motorcraft plug AGSF12-FM1 which is the plug Ford currently recommends for my car. It is two heat ranges colders than what you would probably consider. For you I would suggest copper NGKs stock n/a heat range gapped @.052
seeing youre a n/a cobra, id just get normal NGK's or Motorcrafts. No need to get all fancy like us termie guys and run iridiums.
btw please make sure you gap it right. DO NOT just assume theyre pre-gapped like the guy that had the car before me, theres a big difference between .044 that they come and the .032 that you need.
Has there been issues with blowing the plugs out of the head on 4.6L Mustang engines?? I have people tell me they have that problem with 5.4L Econoline and Truck motors. Is that the case with the 4.6L too?
I want to change the plugs on this 72K 4.6L SOHC motor I am putting into my mod fox, but I am a little scared of doing so. The engine ran great in the car I pulled it out of.
Yes, there has been issues with our motors because of the aluminum heads.
From my understanding, you don't want to run anything more than a copper plug on a boosted format. Mainly due to detonation issues and worries. :shrug:
I just got some Bosch ir fusion spark plugs and should i put some antisieze on the threads? Also those come pre gapped so i dont have to do anything to them except put them in right.
