Greetings.
By the end of the month I should have a sizable quantity of cash saved up, and consequently, I want to give my Stang what it's been needing for a while.
Since I bought it Jan 31 of 2004, it's had two oil changes and a new air filter. I have no service records beyond that. Due to that uncertainty, I want to change out everything that could possibly lead to a problem, within reason and budget. My budget for this is about $500. I can adjust that upwards if I need to.
I searched the forum for all threads relating to tuneups, thoroughly read my Haynes manual, and have compiled a list of everything that I *think* needs to be done.
Additions, comments, deletions, and general encouragement are welcomed.
---- Begin List ----
All fluids are Valvoline unless specified otherwise.
- Replace spark plugs (Standard copper)
- Replace spark plug wires
- Replace PVC valve
- Check and repair EGR system
- Replace air filter (Stocker to K&N, and possibly a CAI)
- Replace fuel filter
- Trans fluid/filter change (MaxLife ATF with Stop Leak)
- Engine oil change (MaxLife synthetic)
- Replace distributor cap and rotor
- Flush out radiator and cooling system (Zerez Super Cleaner and MaxLife antifreeze, 70/30 mix)
- Add fuel injector cleaner (MaxLife Fuel Sytem Cleaner)
- Carb/TB cleaner down intake while running (SynPower Carb, Choke & TB Cleaner)
- Change power steering fluid (MaxLife Power Steering Fluid with Stop Leak)
- New brake fluid and bleed (SynPower DOT 3 & 4 Brake Fluid)
- Change differential fluid along with friction modifier (SynPower Full Synthetic Gear Oil)
- Pull rotors and put new wheelbearings and pack with grease, new wheel seals
- Check and adjust air in tires
- Check timing and replace timing belt (if needed)
- Replace drive belts (if needed)
- Check/clean/adjust TPS/IAC system
- Run codes from ECU
- Check all light bulbs and make sure they're working properly
- Inspect suspension and lubricate chassis
- Replace o2 sensor
- Fill WW reservoir with water and RainX concentrate
- Rotate and balance tires
- Check and adjust front end alignment
- Have battery/charging system tested
- Clean/replace battery cables
- Have brake system inspected and repaired as neccessary, including e-brake
- Adjust and lubricate A/T shift linkage
---- End List ----
Opinion on Valvoline MaxLife Engine Protector
Opinion on proper oil viscosity (Chart in Haynes suggests 10W-30)
Opinion on friction modifier in 7.5 - What's it for?
Opinion on automatic battery shutoff below certain voltage - Possible?
Opinion on EGR system - Does it help or hurt mileage?
Any other tips that would increase my mileage, short of dropping the A4LD and changing to a T-5 (someday!) are welcomed.
- Replace PVC valve
- Replace o2 sensor
---- End List ----
