2 & 3 speed heater motor
I'm not familiar with the wiring of the two speed. I couldn't find a diagram anywhere. Does the two speed have a resistor assembly? You will need a resistor to incorporate at least a low speed.
If you change your switch to a three speed switch and add the resistor assy, you could run all speeds.
Here is a simplified diagram of how the three speed is wired.
