2.3 to 5.0
  • Thread starter Thread starter stang89460
  • Start date Start date Jan 1, 2009
stang89460
14
  • Jan 1, 2009
I have a 91 lx with the 2.3 and I have a 89 5.0 both injected, I also have the complete engine harness and under hood harness from a 89 gt. I removed the 2.3 to install the underhood harness from the gt when I noticed a black box on the passangerside that lookes to be a control module. What is this and is there any post for this kind of swap?
9
91notchbuild
Southwestern Michigan
Feb 20, 2009
  • Feb 20, 2009
not 100 percent sure but my guess would be a cruise control system, ABS, or SRS, you can rule out the cruise and air bags by general knowlege, as far as any other swaps i have a question, i have been told the differences for swaps are this- input shaft is 1/4" shorter/longer on MT's, gearing is different...? plus this, i have a 89 lx 5.0 HO T-5 car, the cable goes from the firewall down and there is a ball that hooks directly through bellhousing to the clutch fork, on my 91 lx 4 cyl it goes same up to bellhousing but then to a kind of pulley system, almost to pull the fork the other way...the bushings are SHOT so its metal on metal, not driving the car now due to the fact i need a new quadrant kit and cannot find this bushing kit!!! going to swap in a 302/347 this spring, how much difference is there in trannys?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 20, 2009
  • Feb 20, 2009
http://forums.stangnet.com/719397-welcome-fox-engine-swap-shop-read-before-posting-forum.html
Moved to 5.0 Tech.
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
G
2.3 turbo question
  • Gibby8438
  • Apr 16, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 25, 2026
NXcoupe
N
J
Cam for 1989 2.3 4 plug
  • Jaycee1964
  • Dec 12, 2025
2.3L (N/A & Turbo) Tech Dec 14, 2025
AeroCoupe
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
