Hi All,
This one is driving me nuts. 87 mustang, 2.3L EFI, 5 spd. Car has 140,000 miles on it.
There is an engine knock in the lower, rear passenger side area of the engine. Did a compression test with following results...
#1 - 160 lbs
#2 - 160 lbs
#3 - 180 lbs
#4 - 160 lbs
The knock comes and goes. It doesn't exist at idle, but only under acceleration, up to about 3 grand, then it goes away. Sitting still, you can barely catch the knock (for a second) during run-up from 1,500 to 3,000 rpm. Driving, it may be loud or it may be barely audible. The engine runs really smooth. Sometimes it will be loud, then I can stop for a minute, restart and the knock is almost gone.
I've tried all different grades of gas. I've gone through various oil viscosities. Oil pressure keeps at a steady 50 psi.
The thought is, rod bearing. However, I've also heard that the 2.3 had a problem with carbon build-up and this could be a cause. The knock sounds like it is coming from the area of cyl 3-4, so with the high pressure on 3, my thought is maybe carbon?
Anyone else run into this. Sooner or later, I'll get around to rebuilding the engine, but for now I enjoy just playing with the car (it is my $450 toy). I just don't want to take the chance of throwing a rod. If it is a rod, it gets parked, if it is carbon, then I'll continue to play.
Thanks in advance,
Dave
#1 - 160 lbs
#2 - 160 lbs
#3 - 180 lbs
#4 - 160 lbs
Thanks in advance,
Dave
