  • 1994 - 1995 Specific Tech
2 questions
  • Thread starter Thread starter Hef5.0weisen
  • Start date Start date Jun 24, 2006
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Jun 24, 2006
  • Jun 24, 2006
Just got home from an 8 month romp around the world....car is broke, go figure.
1st...after installing MM caster/camber plates, can any alignment shop hook up an alignment, for example would the sears automotive be able to do a proper alignment? I have a performance shop close, just doing homework for price and conveinance sake.
2nd...when removing the balancer, how much "uuumph" should be applied to the puller before it starts to slide off. My 220lb self was almost standing on a breaker bar (ever seen a monkey and a football?...I was getting mad) before I decided to walk away and leave well enough alone. The bolt and washer are out, and I am using the proper puller. I sprayed everything down with PB blaster, try again later.
Did a search on both topics already, any new info appreciated.
Thanks,
Hef
MysteryMachine
1,835
Parkesburg, PA
Jun 24, 2006
  • Jun 24, 2006
The place I went to said they "specialize" in lowered cars and that their guys are trained for that. Not sure if that was true or not or even if there is special training for lowered stuff. All i know was it cost me almost $200. They said my tie rods (bumpsteer kit) or the rods that go into the steering rack were't screwed in even and they hade to tear it all down and redo it. Quite possible that was teh first time I had it done and it was after redoing my front suspension (CA bushings, ball joints, struts, cc Plates, bumpsteer kit, and a used spindle on the driver side) I didn't screw with how the things were screwed into the rack though
1TallMF
955
Montreal
Jun 24, 2006
  • Jun 24, 2006
Not sure on the alignment issue, but I have heard of something you could try to take you balancer off. Someone once posted that you can take the breaker bar and put a pipe on the end of it so it can reach the driver's side frame rail. Then you pull the fuel pump relay out (so the engine doesn't start) and give a few quick cranks of the engine with the key. There should be plenty of torque there to pull the balancer. Myself, I would be kind of scared to try this because of the ammount of force involved, but I have heard that it works wonderfully. This might be done better with a 3/4" drive breaker bar and an impact socket. If those break, then that thing 'aint coming off.
T
TheUser
1,859
Springfield, MO
Jun 25, 2006
  • Jun 25, 2006
TallMF: That's to get the bolt loose, which he's already done. I always lay the pipe on the ground, not the car.
Hef: I've never had a problem such as yours when taking a balancer off. Make sure you have the shaft of the puller and the bolts that bolt into the balancer completely straight.
I don't really know what else to tell you.
Good Luck!
M
67 Mustang Tie Rods - Adjustment question
  • mklovell
  • Oct 8, 2019
2K
1965 - 1973 Classic Mustangs -General/Talk- Oct 9, 2019
2Blue2
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
L
(potential) Project Fox-95
  • Lu_St
  • Nov 21, 2014
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 23, 2014
FoxMustangLvr
Install '87-'95 Heads, Cam, Intake Install
  • 5spd GT
  • Sep 25, 2013
  • Resource Discussion Forum
12K
Resource Discussion Forum Sep 26, 2013
Gearbanger 101
Finally, New Tires on order
  • Donny
  • Jun 23, 2009
1994 - 1995 Specific Tech Jun 24, 2009
94-302-vert
