2000 Fully Built GT 5.1 Stroker 14000 obo
rdwyellowguy
2000 MUSTANG FULLY BUILT 5.1 STROKER. OVER 14000 INVESTED. CAR WILL EASILY GO INTO MID 12'S. CAR HAS BEEN PROFESSIONALLY DYNO TUNED NO CORNERS CUT. THE LIST OF MODS IS VERY LONG. THE ALTERNATOR, RACK AND PINION, OPTIMA BATT., STARTER, AND PASS WINDOW MOTOR AND REG. ARE ALL BRAND NEW. OIL WAS JUST CHANGED FOR THE SECOND TIME AT 3K MILES WITH ROYAL PURPLE OIL AND FILTER. CAR HAS SALEEN FRONT CLIP AND COBRA WHEELS. ADULT OWNED AND DRIVEN NEVER ABUSED. BRAND NEW NITTO 555 EXTREME DRAG RADIALS ON THE BACK AND NEW RIKEN TIRES IN THE FRONT. PLEASE CALL OR TEXT WITH ANY QUESIONS PRIOR TO BIDDING. 330-962-8963. HERE IS A LIST OF THE MODS AND I HAVE MOST RECIEPTS FOR IT. CHASSIS HAS 113K ON IT. TRANNY HAS BEEN REBUILT 8K MILES AGO AND THERE ARE 3.73 GEARS AND A NEW FORD RACING POSI UNIT IN THE REAR END WITH ABOUT 8K ON THEM. CAR IS GARAGE KEPT YEAR ROUND! NEVER SEEN SNOW OR SALT! The fuel sending unit needs to be replaced. 13000 OBO.
FORGED CRANK RODS AND PISTONS-3000.00
NEW RINGS-69.09
BEARINGS-115.83
LOWER GASKET KIT-88.11
VALVE JOB 225.00
FLY CUT PISTONS-120.00
MISC. CHARGES FROM MACHINE SHOP-330.00
ASSEMBLE ENGINE-465.00
PATRIOT STAGE 3 ALUMINUM HEADS-1595.00
COMP CAMS XE278AH CAMS-611.95
TRICK FLOW TIMING SET-329.95
TRICKFLOW SILVER VALVE COVER-189.95
P-51 ALUMINUM INTAKE-899.99
SUMMIT RACING 75MM T.B.-169.99
BBK INTAKE-180.00
BBK LONG TUBE HEADERS-469.99
OFF ROAD X PIPE-179.99
X PIPE W/ CATS-389.99
MAC CAT BACK EXHAUST-??
42LB FORD INJECTORS-389.99
90MM MASS AIR METER-299.99
FUEL TANK FROM 03 COBRA WITH DUAL PUMPS-650.00
TRICK FLOW UNDERDRIVE PULLIES WITH S.F.I DAMPNER-189.99
ACCEL COILS-208.95
E3 PLUGS-40.00
GRANETELLI TUBULAR K MEMBER KIT 599.95
INTRAX LOWERING SPRINGS-199.00
KYB SHOCKS-200.00
CENTERFORCE DUAL FRICTION CLUTCH,TOB,PILOT BEARING ALUM. FLYWHEEL-830.00
NITTO 555 DRAG RADIALS-369.90
CROSS DRILLED AND SLOTTED ROTORS-120.00
EBC GREEN STUFF PADS-80.62
B&M SHORT SHIFTER-169.99
STEEDA CLUTCH CABLE WITH ADJ QUADRANT-99.99
ARP BOLTS, MISC GASKETS, ETC.300.00
