Expired 5.1 Stroked, Supercharged, Forged 2000 Gt
Putting this back up for sale. Haven't driven it in 10+
Months. Title in hand.
2000 Mustang GT
Coupe
~17k miles on motor/supercharger.
~1500 miles or less on almost all other mods
0 miles on built rear (just had the rear built, haven't even driven it since)
MOTOR:
5.1 stroker kit
Forged internals
Vortech V2 T-Trim
Aftercooler
Anderson power pipe
2.87 pulley (dyno time)
New belt (dyno time)
03/04 cobra IC pump with relay
Procharger bypass valve
HP292 cams
Updated intake manifold also have Bullitt intake manifold(not installed)
Optima Red top battery. Relocated to the trunk
FUEL:
03/04 cobra hat
Twin 255lph pumps
Modded FPDM
40a KB BAP
KB fuel rail pressure disc
PPRV delete
SCT X3 tuner
Accufab 75mm plenum
Accufab 75mm throttle body
EGR delete
New iac
New tps
Stage 2 colder ngk's (dyno time)
Custom made baffle to prevent fuel starvation
EXHAUST:
Flow tech long tubes
Flow tech o/r x pipe
SLP LM1 weld in
DRIVETRAIN:
Spec aluminum flywheel (8bolt)
Frpp aluminum driveshaft
Ram power grip stage 2 clutch
Frpp tob
Frpp pilot bearing
New clutch fork
New clutch cable
New pivot stud
New transmission mount
UPR clutch cable( ~1200 miles in trunk)
UPR firewall adjuster
UPR triple hook quadrant
Pro5.0 short shifter
Moser 31 spline forged axles
Bronco 31 carrier
Frpp diff cover
4.10 gears
Master rebuild kit
EXTERIOR:
Cobra RR 2.5" function cowl hood
03/04 cobra mirrors
03/04 abc rear cobra bumper. No cobra letters or side markers
03/04 cobra shaved spoiler
99/01 cobra front bumper
03/04 cobra side skirts
Tinted tail lights
Sequential tail lights with relay
Black projector headlights
6K HIDs
Black billet grille
Mach 1 chin spoiler
Welded badge holes on fender
Debadged trunk
20% tint
INTERIOR:
Innovate LC-1 digital wideband with red display
Glow shift digital boost gauge with red display
Dual a pilar mount
All green lighting has been changed to red LEDs
Bullitt shift knob. Powder coated black
Rear seat delete
Bullitt pedal covers (not installed)
SUSPENSION:
Flsfc
Eibach sport lines with no isos
Sve upper and lower control arms
Steeda x2 ball joints
WHEELS/TIRES:
FR500's black with chrome lip
17x9 front. 245/45/17 nitto 555's with ~800 miles
17x10.5 rear. 315/35/17 Mickey Thompson ET street 2 with 300miles
Tuned by HPP performance in lewisville,TX
Currently flat white primer. I will be getting it painted sonic blue soon.
$9,500.00
5.1 supercharged GT - YouTube
Vortech aftercooler pump died while getting tuned so couldn't finish tuning. New pump was put on last week and will have a final tune early next week and will have final numbers then.
Made 472/456 on run #8. On run #9 made 467/454
HP292 Cams - YouTube
Will get more pictures when I return home from work.
Some hit the bumper a week after getting it
Just replaced all injector o-rings today
Put on valve cover breathers along with a fresh oil change
5w-20 synthetic
