2000 gt computer issue
quick281
I have a 2000 gt that got hit by lightning. I turned it on afterwards and smoke came from around radio area, the airbag light is on and dinging, and the radio and wipers started acting up, now they both quit at the same time. What should I do to try and fix it or what could be wrong with it ???
If you turn the key on and do not crank, what happens after the dash light prove out? Does the theft light go out? Does the mileage show? If yes, it's likely the PCM is functioning at some level.
The other way to test the PCM is to connect an ODB2 reader and attempt to download any DTC codes. If the PCM and ODB2 reader talk to each other, likely the PCM is working.
The PCM is located in the passenger's kick panel. IMO, there's no reason to remove it unless it is bad.
The easiest way to find the ground behind the center console is to remove the radio and follow the black wires from the radio.
There are several other control modules behind the dash (air bag, seat belt, GEM), a visual inspection may turn up the module that smoked.
