2000 GT-Front Brakes Not Releasing
stormsedge
5 Year Member
Jun 17, 2018
452
208
63
Here
Took my granddaughter out to teach her to drive a stick (in my 2000 GT). She was doing okay, but a bit flustered with the lowness and “noise” of the car. At one point, I saw her force a pedal to the floor and realized it was probably the brake pedal vice the clutch. After that, she had problems getting the car to pull off…something was dragging (in retrospect). I could smell what I thought was the clutch.
On the way home, the car had lost its snap on acceleration, like towing a trailer.
When I got it home, the car held itself in place without the parking brake (rut ro) on my steep driveway.
A walkaround found smoking hot right front…jacking it up showed both front wheels almost locked up. I didn’t check the rears.
My plan for a cool morning is to put it on jacks and bleed the brakes to see if I can get them to release, but I’m thinking a new master cylinder may be in order if she pushed past the seals.
Thoughts? ((Thanks))
Like said, the front calipers on the 99-04 GT/V6 are notorious for seizing. It's a VERY common issue, especially on cars that are seldom driven, and on brake fluid that likely hasn't been changed for a while.
Caliper replacement is needed. Just be mindful that a reman caliper may have the same issue, as many of the cores turned in were due to seized calipers. So they may or may not have been repaired properly.
If you were ever considering a 13" brake upgrade for your car, now would be a good time to do it.
