2000 GT with Mach system
1000 = 10" sub in trunk... and it's a bitch to upgrade your system. You have to basically replace everything unless all you want to do is swap the head unit.
I just swapped the head unit and put in a sub to my 460 and called it a day.
That's what I remembered hearing ... he can't just swap in some Alpine speakers (same size as stock) in place of his old ones, correct? Why?
You can't. the mach 460 speakers are different Ohms, you'll end up /w either lower sounding speakers (to much ohms = lower volume) or burned up amps (to low ohms = pulls to much power).
besides, the stock 460 amps are like 2% THD which is a lot of distortion, if you're actually going to replace the speakers in the doors why not just run new wires to the deck. I would only stop at replacing the Head unit... if you do anymore work you might was well go all the way and replaced the wires and amps in the back.
