2000 mustang GT fuel pump relay
The fuel pump is controlled via the CCRM. The CCRM is located in the front right fender well. Best to remove the fender liner to gain access.
However I would encourage you to perform the analysis and follow where the trouble shooting takes you.
1996+ Crank with no start check list
https://www.allfordmustangs.com/forums/4-6l-tech/336452-1997-mustang-wont-ignite.html
Pay special attention to the initial key on procedure and verify that the fuel pump primes. Don't be in a hurry to crank the motor. Turn the key on and make note of what happens.
If you insist that the CCRM is your problem, here's a thread to trouble shoot the fuel pump.
https://www.stangnet.com/mustang-forums/threads/fuel-pump-not-running-electrical-diagnosis.906103/
Nope i replaced the CCRM a FOMOCO part, so what your telling me is that their is NO FP relay at all?
No. I did not say that at all. The CCRM is most certainly a relay. But it's a combined relay for multiple things such as Fuel pump, PCM, AC clutch. It is not a standard "cube" relay as used in many other "applications".
Have you reviewed the information provided? There's a complete step by step process that if the requested information is provided will help give focus to trouble shooting.
As a reminder there are other things external to the CCRM that could "cause" it to not work. It's all laid out in the links provided.
