2000 Mustang GT Ticking help!?
johnthebaca
I recently rebuilt my engine with the 5.1 Stoker kit from Coast high. Replaced almost everything on the engine. Oil pump water pump and i got the heads cleaned and a valve job. Now 4000 miles later its starting to tick. It ticks louder at start up and continues to tick when its warmed up. The tick gets a bit quieter when its warmed up though. Gets faster with RPM Its on the passenger side. Thought it might be a lifter or rocker so i replaced all 8 with no luck. Any help would be greatly appreciated!
Heres a video of the noise:
I already had a mechanic look under there. Say by what he could tell everything looked okay. Replaced all the rockers and lifters. He said the cams look good too. May a valve?? Or guide??
it maybe a cam chain tensioner not pumping up fully. I would pull the vavle covers (i know its a pain) and put towles on the inside fenders, start it up and see if the chain is slapping or maybe you'll find something eles.
In the first vid the sound, to me, is too heavy to be a valvetrain tick. I'd call that more of a "knock."
In the 2nd vid I get the same feeling. Sounds like there's a reciprocating assembly knock. But something sounds "sloppy" to me. It might be worth pulling the front cover to inspect the timing chains, guides, tensioners etc...
I changed all the spark plugs and still had the noise.
And yea the noise is a bit loud when I start it cold like in these videos but after I drive her about 30 it quiets down. But what kind of knock would be so consistent like this. I was thinking if it was a rod bearing, blown rod, or piston play it would be a bit more unconstistent. But then again I hear so many bad things about these 5.1 stroker kits blowing up after a few thousand miles.
And also it sounds like the sound is coming from to far back to be the timing assembly. It's mainly the loudest right behind the intake plenum closest to the fire wall. Anythings really worth a shot to help this stop though.
It hasn't gotten any louder or gave me any problems yet. No loss of power or anything. It's hard to hear anything at high rpm because of my exhuast. But I was thinking about just taking it to ford and having the hook up all the special tools they have to try and find it out. But as long as it doesn't give me any problems. It's more annoying than anything right now.
So just an update i went under the car and this is what i found. 2 EXTREMELY loose transmission bolts that connect the bell housing to the motor and 1 bolt that was completely gone! I haven't been able to check the two top bolt because i cant reach them! Like wtf its only been 4000 miles since this rebuilt! Can i sue this mechanic if he refuses to fix it or what?
