2000 Mustang GT wont start
jimn411jm
15
Conroe Texas
My car started fine one day. The next day it wont fire. Turns over but wont start. Battery cables weren't getting a good connection so I fixed that problem but still wont start. The car sat for a couple years as my son had wrecked it. Where I work has a body shop class that did the body and paint. The instructor started the car and moved it to the parking lot the day before I picked it up, Thats the last time it ran. It has tried to fire once but it was kind of weak sounding. it turns over fine without jumping it. Any help is appreciated ( I pressed open the valve on the fuel rail on the right side of the engine and nothing, not sure if its supposed to be pressurized with the motor not running)
  • Sponsors(?)
PSKSAM2
703
NJ
mywebpages.comcast.net
Maybe the fuel pump died? If it sat for a couple years, I could see it dying when you start it back up with some dodgy gas. Mine died at a dealer when I was having some routine maintenance done, had shown some signs, but it really died and they couldn't start the car, wanted $900 to replace the entire unit. I got it started and limped it outside, but didn't make it out of the parking lot. Had it towed home by roadside assistance and replaced just the fuel pump, not the whole sender for about $100 plus my labor of dropping the fuel tank. Any check engine light or codes?
jimn411jm
15
Conroe Texas
I have no way to check codes, No check engine lights. I think you are right about the fuel pump. I'm going to get a new one and try that, also new filter.. Thanks for the info
wmburns
SN Certified Technician
Aug 14, 2009
5,825
501
194
Houston Texas
IF the only thing wrong with your car is a bad fuel pump THEN it should "hit" on a small amount of starting fluid.
If trying to trouble shoot a possible bad fuel pump the "gold standard" is to test for key on power at the trunk mounted IFS switch. IF there's no key on power at the IFS switch, THEN the problem is upstream towards the CCRM.
If there's key on power at the IFS THEN the problem is down stream towards the fuel pump.
Here's some more information that may help.
1996+ Crank with no start check list
jimn411jm
15
Conroe Texas
i got an obd2 adapter and program for my tablet. Said no codes stored in the ecm, So I'm pretty sure its the fuel pump. Thanks for all the help It's truly appreciated
jimn411jm
15
Conroe Texas
Update : Sprayed starter fluid in the intake and it started and ran for a few minutes but died, Started again and ran a few minutes and died again , next time started without starter fluid but only ran about 5 minutes and died so I'm pretty sure either the fuel pump is going bad or the fuel filter needs changing or both
Reactions: Onesick99GT
Onesick99GT
359
47
38
33
Dayton, Ohio
Replace the fuel pump and filter.
Thread starter Similar threads Forum Replies Date
S 2000 Mustang V6 wont start SN95 V6 Mustang Tech 1
R 2000 mustang gt pro charger help 1996 - 2004 SN95 Mustang -General/Talk- 1
H 2000 mustang gt should I supercharge 1996 - 2004 SN95 Mustang -General/Talk- 4
R New member 2000 Mustang,looking for guidance. The Welcome Wagon 3
M For Sale FS: 2000 Mustang GT Track Car / 62k Miles / 5k on Motor / Full Roll Cage / California / $5,000 OBO SN95 Mustangs For Sale (1994-04) 0
R For Sale 2000 Mustang Turbo 6 speed SN95 Mustangs For Sale (1994-04) 1
F 2000 Mustang V/6 Standard Amp 1996 - 2004 SN95 Mustang -General/Talk- 3
T_Roberts Radiator Hoses and Pulleys on a 2000 v6 Mustang 1996 - 2004 SN95 Mustang -General/Talk- 0
J 2000 GT Idle/Running Issues SN95 4.6L Mustang Tech 6
Misti 2000 Ford Mustang GT 4.6 - Rear Differential 1996 - 2004 SN95 Mustang -General/Talk- 12
ryansgts 2000 gt e85 conversion? 1996 - 2004 SN95 Mustang -General/Talk- 0
Misti 2000 Ford Mustang Gt 4.6 - Waterpump 1996 - 2004 SN95 Mustang -General/Talk- 4
W Engine 2000 ford mustang gt SN95 4.6L Mustang Tech 2
Misti 2000 Ford Mustang Gt 4.6 1996 - 2004 SN95 Mustang -General/Talk- 2
nathanruschill 2000 Mustang Gt auto starting issue!! SN95 4.6L Mustang Tech 3
S Looking for all things great! 2000 Mustang Gt (Raush w/o the supercharger) for now. SN95 4.6L Mustang Tech 0
S 2000 Mustang GT surging idle/cruising SN95 4.6L Mustang Tech 3
C Gauges on 2000 gt slow to work after starting 1996 - 2004 SN95 Mustang -General/Talk- 6
O Questions about 2000 Mustang The Welcome Wagon 0
V WTB/Trade WTB 2000 Mustang V-6 Convertible front seat upholstery Parchment Interior Exterior Parts 1
V WTB/Trade WTB 2000 Mustang V6 tail light Interior Exterior Parts 0
2 2000 Mustang GT Exhaust Question? 1996 - 2004 SN95 Mustang -General/Talk- 4
A 2000 mustang issues 1996 - 2004 SN95 Mustang -General/Talk- 6
D 2000 Mustang V6 cranks, no start, and no fuel pressure (BUT has started intermittently) SN95 V6 Mustang Tech 3
C 2000 Mustang - Which torque converter do I need? (Still learning) 1996 - 2004 SN95 Mustang -General/Talk- 3
Misti 2000 Ford Mustang Gt 4.6 1996 - 2004 SN95 Mustang -General/Talk- 8
L 2000 ford mustang gt fuel pump no power 1996 - 2004 SN95 Mustang -General/Talk- 1
J 2000 Mustang GT wheel fitment SN95 4.6L Mustang Tech 1
P Need Help ! 2000 Mustang GT SN95 4.6L Mustang Tech 1
T Help!! WHAT MODS FIRST? 1996 - 2004 SN95 Mustang -General/Talk- 41
Misti 2000 Ford Mustang Gt 4.6 1996 - 2004 SN95 Mustang -General/Talk- 4
H Help! mass airflow sensor 1996 - 2004 SN95 Mustang -General/Talk- 5
T Is my 2000 Mustang Gt broken 1996 - 2004 SN95 Mustang -General/Talk- 4
Misti 2000 Ford Mustang GT 4.6 1996 - 2004 SN95 Mustang -General/Talk- 7
E New Guy... The Welcome Wagon 2
R 2000 mustang runs rough and dies when warm SN95 V6 Mustang Tech 10
R For Sale V2 Vortech Supercharger Kit 2000-04 $4500 OBO Rochester NY Engine and Power Adder 3
C Progress Thread 2000 Mustang GT 1996 - 2004 SN95 Mustang -General/Talk- 0
W New Owner, 2000 Mustang GT Dead Battery Misfire? 1996 - 2004 SN95 Mustang -General/Talk- 1
R 2000 4.6 Mustang with crank no start 1996 - 2004 SN95 Mustang -General/Talk- 15
S 2000 Ford Mustang 3.8l Upper intake sound The Welcome Wagon 3
L 2000 mustang gt bbk valve covers need help 1996 - 2004 SN95 Mustang -General/Talk- 0
S I have 2000 Ford Mustang 3.8l I don't know what's wrong with it I changed my heads and still same 1996 - 2004 SN95 Mustang -General/Talk- 15
J 2000 Mustang 3.8L battery drain SN95 V6 Mustang Tech 4
F Proud 2kGT Owner Looking for Info The Welcome Wagon 1
S 2000 Mustang Power Windows Help 1996 - 2004 SN95 Mustang -General/Talk- 2
T 2000 V6 Mustang and my climate control unit stuck on Defrost SN95 V6 Mustang Tech 4
S Engine 2000 Mustang Idle issue SN95 V6 Mustang Tech 1
R 2000 mustang saved from the junk yard 3.8 1996 - 2004 SN95 Mustang -General/Talk- 0
R 2000 Mustang V6 bout 156k Mech issues 1996 - 2004 SN95 Mustang -General/Talk- 1
