2000 RPM miss/stumble? - solved maybe
I just replaced my well worn (200,000+ mile) 4.6 with a brand new, "old stock" 2004 4.6..the new engine was complete from oil pan to throttle body (even a belt and oil filter)
after the swap I have a significant miss/stumble/vibration right about 2000 RPM...I thought it might have been the Energy Suspension motor mounts, but it seems worse once the engine gets up to temperature so I'm thinking it's not a mechanical issue
a couple other things; the place that did the swap* didn't use the new engine's wiring harness and may not have used the new injectors...I have blocked off the hoses to the heated PCV because it wasn't plugged it, and that may have made a slight improvement (by that may be just in my mind)
any thoughts guys?
*I intended to do the swap myself, but the place I had planned to do the work disappeared and my chronic back issues picked a really back time to re-appear so I had to farm it out...the place is a Mustang shop and they seem to know what they are doing :-/ )
any thoughts guys?
....but I think I got rid of that nasty miss/vibration/hesitation my car had...
