  • SN95 4.6L Mustang Tech
2001 Bullitt t3650 Tranny
  • Thread starter Thread starter Coreyned
  • Start date Start date Jun 7, 2007
C
Coreyned
45
  • Jun 7, 2007
Hey guys im new to this thread so how are ya? ok i bought a mustang bullitt and the transmission sounds ****ty. 3rd gear grinds when i try to put it into gear but sometimes if i accelerate slowly it will go in without grinding. i was going to buy a whole new t3650 transmission and put it in but i was wondering if there is a cheaper way like just buying the gears. please reply with what you think i should do,, and how hard it would to do it.. me n my friend are going to attemp to fix this tranny, we never worked on any serious engine or any transmission work. i downloaded and printed a service manual on how to take apart and put back together a Tremec 3650 transmission. thanks for your replys.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 7, 2007
  • Jun 7, 2007
you must use a torch to get everything apart and back on. itsnot easy. look into a TKO 500 or 600 for a cheap replacement tranny. oraT56 6 speed would be even better!
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jun 8, 2007
  • Jun 8, 2007
Did your tranny have the TSB done on it ?
W
WydOpn
39
Michigan
Jun 8, 2007
  • Jun 8, 2007
Sure, you can buy new gears, synchros, etc...and that transmission isn't that hard to repair yourself if you have the right tools. There's also an upgrade kit available with better synchros and beefed-up shift forks - depending on when the trans was built, yours might already have these, but if not, I'd definitely recommend it. My Dad and I have done several 3650 re-builds and I can scan our notes (there's a few little quirky things the manual doesn't describe well) and give you a list of the tools you'll need if you decide to do it yourself...
Mustang5L5
Mod Dude
Feb 18, 2001
43,258
17,941
224
Massachusetts
Jun 8, 2007
  • Jun 8, 2007
It's a tough trans to work on. I would never try one. I can rebuild a T-5 with my eyes closed, but the 3650 is a scary thought for me
C
Coreyned
45
  • Jun 12, 2007
i dont think the upgrade kit is on it, not sure i just bought the car but the whole transmission all gears sound crappy. yea were gona do it ourselves instead of paying this guy that was going to do it $500 i thought id spend that on tools and parts instead. and save the $1000 on the new T3650.....can a T56 6 speed and the TKO's fit perfect in my car? 2001 mustang bullitt. thanks for the replys sory i took so long 2 reply havent been on
C
Coreyned
45
  • Jun 12, 2007
yea could u scan ur notes and tools i would need. id rather buy tools and learn how to do this in case it ever happens again which im sure it will
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Jun 12, 2007
  • Jun 12, 2007
C
Coreyned
45
  • Jun 12, 2007
today i was gona change my tranny fluid to royal purple n see what happens.. maybe it will help it cuz i just bought it from a 16 year old and i dont think he rly knew what he was doing totaly so ima try that but still give me the info thanks
Dusstbuster
I love meat more than anything! I just have a spec
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Jun 12, 2007
#10
  • Jun 12, 2007
  • #10
I mean this in the most non flamatory and nicest possible way...type out complete words and use proper punctuation or you're going to get annoying very fast and people won't want to help you. You seem cool and all but reading your posts makes it sound like you're a 13 year old asking for help.
As for the issue, I know the 3650's are known for grinding gears and such and thought that dealerships usually fixed the issue for free or fairly cheap. Someone else who's had the issue should be able to chime in. Also there is a fairly lengthy thread regarding 3650 issues, search in the 4.6 Tech area for it.
C
Coreyned
45
#11
  • Jun 14, 2007
  • #11
hey could you still give me the info on how you changed your tranny.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 14, 2007
#12
  • Jun 14, 2007
  • #12
a TKO or T56 will swap right in
C
Coreyned
45
#13
  • Jun 14, 2007
  • #13
which is a better transmission? and which one is 5speed, 6speed wouldnt I have to changed other things if i went to a 6 speed
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 14, 2007
#14
  • Jun 14, 2007
  • #14
either one CAN have an upgraded 26 spline input shaft. that would require a new clutch. the T56 is a 6 speed. TKO is a 5 speed.
as far as better transmission, there are different versions of each. a regular T56 like a cobra one is weaker than a Viper Spec T56. a TKO 500 is weaker than a TKO 600.
i have a Viper T56 in my Paxton car and my buddy has a TKO 600 in his KB car. both are strong trannys but my T56 is a MUCH smoother tranny. BUT mine is also about $4000 for a complete kit compared to the TKO 600 costing about $2000 for a complete kit.
the T56 requires a modified cross member and a shorter drive shaft. the TKO is a bolt in replacement
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 14, 2007
#15
  • Jun 14, 2007
  • #15
what is done to your car and what are your plans for it? that will help us tell you what trans is best for you.
C
Coreyned
45
#16
  • Jun 15, 2007
  • #16
right now its a stock bullitt gt, but i want to eventually get headers, bigger throttle body , maybe cams.
C
Coreyned
45
#17
  • Jun 15, 2007
  • #17
do you know for the bullitt gt what spline input and output the transmission is and clutch and rearend?
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 15, 2007
#18
  • Jun 15, 2007
  • #18
you have a 10 spline input now.
a cobra T56 will be more than enough for you. a TKO 500 may even be overkill. you dont need a really strong tranny for what you listed
C
Coreyned
45
#19
  • Jun 18, 2007
  • #19
the T56 what would i have to do to do that swap? anything other then the shorter driveshaft?
4.6stang
10
Florida
Jun 18, 2007
#20
  • Jun 18, 2007
  • #20
t56
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Y
2004 Mustang GT AUTO (4R70W) Grinding noise when going in R or Drive does it as I put it into park too
  • yellowandblack
  • Dec 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Dec 21, 2024
89ripper
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
