B Black GT Active Member Sep 8, 2018 148 9 28 Jacksonville, Florida Feb 6, 2019 #1 Feb 6, 2019 #1 Is it normal for a clutch to slip a little the first time it is used on cold mornings? Its not slipping bad at all and only does it in first gear the first time the car is used.
STEVE PATTON I smell a conspiracy Jan 6, 2019 201 89 53 ohio Feb 6, 2019 #2 Feb 6, 2019 #2 not normal,wiggle your clutch fork at the bellhousing .If it feels loose you are putting a clutch in it soon ,if tight adjust until you have slack Reactions: Black GT
