  • SN95 4.6L Mustang Tech
2001 Cobra with vibrating issues!!! please help!
  • Thread starter Thread starter PhillyRican69
  • Start date Start date Jul 17, 2005
P
PhillyRican69
  • Jul 17, 2005
I have a 2001 Mustang Cobra that has a solid rear axle....I purchased it like that and the only mods i have on it is: Magnaflow exhaust, magnaflow offroad xpipe, densecharger cold air kit with a pro-m 80 maf......I was told that I should replace the driveshaft and the flywheel, and to also get a better clutch.......someone else told me that its a common issues with that year cobra, and its a combination of the bottom end of the engine and tranny..........I NEED HELP!
Has anyone out there experienced this vibration problem! I usually feel it in 4th gear around 100-110 mph or so! I can take first thru third gears to redline with no vibrating.....only after that at that speed range.....ITs really bad.....I hear a moaning noise and my shifter shakes around and i feel it in the pedals too!!!
PLEASE ADVISE!
Thanks !
D
Duane123
76
Los Angeles
Jul 17, 2005
  • Jul 17, 2005
I also have a 2001 Cobra but don't have that problem. Start simple. Are your tires balanced and in good order?
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Jul 18, 2005
  • Jul 18, 2005
Whoa, whoa, whoa. Try indexing the driveshaft before you "throw parts at the problem."
To index the driveshaft, simply unbolt it and rotate it 90 degrees. Take note of the original configuration first, in case you need to index the driveshaft multiple times before the problem gets better.
Improperly balanced tires could also be a culprit...
Additionally, you might want to get in touch with user Lo Pony (try e-mailing him via his profile instead of sending a PM). He published a "driveline vibration" webpage specifically addressing the 99/01 driveline vibration issue in great detail (targeted at 99/01 cobras that had the IRS - some of the information was also pertinent to solid axle cars though). Unfortunately, his webpage is no longer hosted - it was an excellent resource! According to his user profile, he last visited the site in Sep of 2004...
G'luck.
triggz
1,218
Gadsden, AL
Jul 18, 2005
  • Jul 18, 2005
What do you know about the 8.8 in there? Does it have factory gears, axles, etc?
But the others are right, start simple. Check the tires for odd wear first and foremost and work your way backwards through the drivetrain.
tomustang
Psychotic Member
3,434
McLean Hospital
Jul 18, 2005
  • Jul 18, 2005
After 'as stated above' look at the Upper control arms and check if there's alot of play in the bushings: both axle mount and chassis.
P
PhillyRican69
  • Jul 18, 2005
the tires are in great condition and professionally balanced....so i really doubt it could be that.....I will be taking the car to a shop to do an over all inspection.
P
PhillyRican69
  • Jul 18, 2005
honestly....i dont know....but im pretty sure that the gears are stock.....I had 4.10's on my old 96 cobra and i know how that affects your rpm gauge.....so its not that.....as far as axles, im going to take it in to be looked at.
P
PhillyRican69
  • Aug 3, 2005
i will have ford look into that for me......but on another note, I see that you have a magnaflox catted x-pipe....i have the off-road version and was wondering if you also suffer from what i do?
if my car is idling and i hit tha gas hard....its sounds like it bogs down low! like its conjested but it clears in about a second or so then it fine?
do you think that related to the fact that I dont have cats and therefore lack of backpressure?
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
