2001 gt passenger door replacement help
I imagine the convertible door is the same as the coupe. If you are worried about the wiring being different a visual check of the door panel should answer that question. Just see if the switches are in the same place and alike. If worse came to worse you could swap the wiring harnesses with your old door.
