  • SN95 4.6L Mustang Tech
2001 Mustang Gt Supercharger or Turbo
  • Thread starter Thread starter curious_mofo
  • Start date Start date Jan 13, 2007
C
curious_mofo
  • Jan 13, 2007
I am looking for a supercharger kit or turbo kit for my 2001 mustang gt conv. with manual trans. If anyone has one or knows of one thats under 2000 I will consider. Just looking for extra horsepower. Does any one know how much horsepower the stock gt engine will hold or handle? Thanks
T
Torinalth
952
Clayton NC
Jan 13, 2007
  • Jan 13, 2007
search Ebay for used, and hope to find a killer deal... otherwise no chance at under 2k. stock block can handle 400-500 depending on tune and how the power is made.
also, try a search.
Torinalth
04YELLOWGT
1,135
Indiana
Jan 13, 2007
  • Jan 13, 2007
I would do nitrous if you want to be under $2000. If you can afford it get the MPH Mongoose kit that come with EVERYTHING you need for $3800, including a dead on tune. Its almost impossible to get a SC for $2000 and if you do there is prolly something wrong with it or missing a buch of stuff.
As fas a nitrous you can get a kit with everything you need minus tune for about $1500. Run a 100 shot on it and have amazing power and torque.
Also stock 4.6 can handle about 400-450 rwhp safely with a good tune. Anyhing more is pushing it.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Jan 13, 2007
  • Jan 13, 2007
Turbo kits are quite expensive.
T
Torinalth
952
Clayton NC
Jan 13, 2007
  • Jan 13, 2007
as long as he can bend his own pipes and do his own tune he could get an Ebay turbo and make his own system... but everything gets dangerous when you go cheap on everything
98V6 K.I.T.T.
2,049
Everett, Washington
Jan 13, 2007
  • Jan 13, 2007
For a blower, you are going to be looking more at around 3K or more for the 4.6, turbo alittle more then that. I would also maybe consider a nitrous kit, if you just want the extra power for the track, or only once in awhile. Which then you could really have it up and running for about a grand give or take a couple hundred on average.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 14, 2007
  • Jan 14, 2007
i have about $6500 in my s/c setup. i would say that you are SOL trying to find one for 2k. i'm with everyone else, for your price range a good shot of : paul walker : "NAAAWWWWSS" would be the best route.
hotmustang331
2,967
Bastrop,TX
Jan 14, 2007
  • Jan 14, 2007
^ +1 I have about the same in my turbo setup, and I bought MOST of the parts off EBAY BTW (not retail or it would have been MUCH more)....so yea turbo or S/C shouldnt be considered. You COULD peice togethor a cheap turbo kit...I think Ricky Bobby has done this for a few people.
But the problem is all of the parts you will want to get for safety and reliability. Gauges, clutch, fuel system, dyno tune, ect. No matter what, your going to spend some serious cash with the S/C or turbo setup.
BIG +1 on the N20....ONLY go with the NX kit with the safety upgrades though. Its the best out there from what I have seen. Just do some searching, and you will find ALL the info you need on this site.
the98stang
2,408
Clovis, CA
Jan 14, 2007
  • Jan 14, 2007
You won't find a new kit for under 2 grand. Even a used kit is hard to find for under 2 grand. With a used kit you will probably spend 2500-3500 dollars (including a tune/pump/injectors). A new kit will cost even more. Our stock block can handle 400-450whp with a great tune. But that is no guarentee. Get the car compression tested before you even THINK about buying a SC.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 14, 2007
#10
  • Jan 14, 2007
  • #10
there was a novi 2k with the bracket on MPH last week for $1000.
you still need fuel pump, injectors, maf, s/c piping, oil feed and return lines, tune and dyno time
04YELLOWGT
1,135
Indiana
Jan 14, 2007
#11
  • Jan 14, 2007
  • #11
^^ Which means hed still have over $1000 in buying the extra parts. Do the nitrous and be done.
Rickey_Bobby
332
Sarasota, FL
Jan 14, 2007
#12
  • Jan 14, 2007
  • #12
I would suggest turbo if money wasn't a factor. Making your own kit requires a LOT of knowledge and a lot of luck. If you are looking for a SC for under $2K, I have a Vortech V-2 SQ that has 8K miles on it. Comes with a few different pulleys, the bracket, intake, belt, and boost pipe. PM me if you are interrested.
-Steve
C
curious_mofo
#13
  • Jan 14, 2007
  • #13
Right now I have a full exhaust(Borla and bbk) and a couple of minor mods. I was just looking for some extra power and from what i hear a supercharger is the way to go. Ricky Bobby, I am interested with the kit. If ya can send pics, send them to dyjak31@yahoo.com. Also what else will I need to complete the kit? Also i was thinking a cam. What is recommended for both sound and performance? Any other minor mods does anyone reccomned to increase horsepower? Thanks for the help, I just want to beable to hold my ground on the road.
Rickey_Bobby
332
Sarasota, FL
Jan 14, 2007
#14
  • Jan 14, 2007
  • #14
If you go the SC route you will need the following:
255LPH fuel pump
42# injectors (I have a used set 8K miles on them too)
Programmable chip
Custom tune
Things that will help (in order from most noticable to least noticable differance)
Gears 3.73's
Big sticky tires
Cams
I will email pix soon.
-Steve
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 15, 2007
#15
  • Jan 15, 2007
  • #15
you aint in 5.0 country anymore, around here we run 2 cams!
hotmustang331
2,967
Bastrop,TX
Jan 15, 2007
#16
  • Jan 15, 2007
  • #16
Cams are not needed...you will just have to detune your engine because they produce ALOT of extra power....more than your stock shortblock can handle. Its really kindof a waste of money unless you plan on going with a forged engine soon .
And so you know, the fuel pump RB is probably refring too is the SVT focus unit (which actually flows like 23X I think). Curious, do NOT confuse what RB is talking about with the 255LPH unit from walbro...im sure Ricky knows just as well as the rest of us that those Walbro pumps have a high failure rate accross the boards.
You really have 3 choices inorder from least flow- greatest....SVT focus, SVT cobra pump, or Ford GT fuel pump. First 2 should drop right in...GT requires a bit of modification
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
