  • SN95 V6 Mustang Tech
2002 mustang missing trans dipstick
  • Thread starter Thread starter mikec35
  • Start date Start date Apr 18, 2005
mikec35
233
NC
Apr 18, 2005
  • Apr 18, 2005
I bought this car with 28,000 miles 1 yr ago. Had it at Super lube for an oil change. They came out and told me that they were trying to check the transmission fluid and it was missing the dipstick. I see the tube and it is covered with dust inside as far as you can see by shining a flashlight. This was bought used from the local Ford dealer that supposedly did a 100+ point inspection. How they could check the transmission fluid I do not know. Could this thing develop trans problems since it has sucked dust in? Should I just buy a new dipstick and forget about it or go back and see if they will atleast change my transmission fluid?
N
n0v8or
604
Rhode Island
Apr 19, 2005
  • Apr 19, 2005
The "100+ point inspection" means the inspection is worth 100+ points, not that they actually check anything besides youir credit score.
SteveC
633
Mason, OH
Apr 20, 2005
  • Apr 20, 2005
If your car is a 5-speed, they have never had a dipstick.
Some other newer Ford automatics (like the Explorers) do not have a dipstick either since they are "maintenance free"
mikec35
233
NC
Apr 20, 2005
  • Apr 20, 2005
Its an automatic. I should have mentioned in my 1st post. I have purchased a new dipstick and have installed it. I am going to have my transmission fluid changed. Any opinions on the flush method vs. drop the pan and filter?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 21, 2005
  • Apr 21, 2005
the completely proper way is on crownvic.net http://www.crownvic.net/tech/transservice.htm
they use the same transmission. only thing i recommend is having more fluid on hand. make sure that you use Mercon V only. do not get Dexron3/Mercon with a tube of modifer fluid. that stuff hardly ever works. changing the filter is a really good practice to do. there is a OEM pan for the 4r70w that has a drain plug in it. i think it is used on the econoline vans. having a drain plug in the transpan makes futer services so much easier.
mikec35
233
NC
Apr 21, 2005
  • Apr 21, 2005
Thats a great article! Thanks.
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
