Looking for some help here, (I searched and searched some more and didn't find much). A little background may help you help me.. I have an '04 GT (5-spd) that had some bad wiring done by the previous owner for LED lighting and the interior caught fire basically melting the center console area and the wiring harness. I got the car "as is" and I stripped the interior down to nothing but the steering wheel and got a good harness out of an '03 GT (auto). The new harness is in and I want to start the car to see if there are any gremlins and to verify it runs before putting all the interior back together. I had PATS removed from the computer and I also have a new gauge cluster (out of the same '03) and PATS was keeping the fuel pump from coming on. Before I connect the computer (just got it back from the tuner), I want to verify that the voltage at the computer is correct so I don't fry it when I try to start it or damage something else. I have a pin out diagram and pin 55 (reference voltage supplied at all times - overload protected) and pin 90 (reference voltage) are not showing anything on the volt meter, with the key on at the 2nd position or with the key removed. When I turn the key to the 2nd position the fans come on and I hear relays clicking, but no voltage at the connector. Looking for suggestions as to why there isn't any voltage at the connector. Battery shows just over 12v, and grounds on the harness are connected. No other visible damage to any other wires/connectors and everything that can be connected is (meaning there is no dash/console so the connectors for the radio/heat/lights are not connected). Any assistance on finding voltage to the computer would be much appreciated!
