- Jan 1, 2017
- 12
- 2
- 13
Earlier this year my CEL came on and I saw that (P02270) it was my downstream passenger O2 Sensor reading lean (This was completely random and there were no changes or modifications that occurred to cause it), figured the sensor was bad or the cat was bad and thought id wait until I got closer to emissions to deal with it (big mistake).
I swapped out the cats with new ones and replaced both downstream O2 sensors and within a day the CEL was back and the same code (P02270) relating to downstream O2 sensor bank 1 running lean. I went back under made sure everything was tight and for the sake of it installed new upstream O2 sensors (MOTORCRAFT DY1401). The same downstream sensor code returns, this time with a new code (P0133) stating bank 1 sensor 1 is slow to respond.
I decided to check the voltages to each of the O2 wires while the car was on but not running and got the following:
What I found very strange was that both heater wires show as 11.72 volts for driver side upstream. I felt the other voltages were so small that they might as well have been insignificant however they were constant except for the passenger downstream which had its signal and sensor voltage swapped relative to the others.
lastly I can look at my O2 sensor readouts using an OBDII monitor, both upstream sensors appear to function normally looking at the data graph.
For the downstream sensors drivers side sits at 0.045 volts occasionally spiking. Passenger side sensor pretty much sits at 0 volts and never moves other than a very random quick blip.
I'm unsure what the issue is at this point, I thought there was damage or a kink in the wiring harness somewhere but I cant find anything.
Any suggestions at this point would be greatly appreciated.
| Sensor | Heater 1 | Heater 2 | Signal | Sensor Ground |
| Passenger Upstream | 11.72 | 0.056 | 0.065 | 0.056 |
| Passenger Downstream | 11.72 | 0.056 | 0.065 | 0.056 |
| Driver Upstream | 11.72 | 11.72 | 0.056 | 0.065 |
| Driver Downstream | 11.72 | 0.056 | 0.065 | 0.056 |
