2004 SVT COBRA, TURN KEY RACECAR, 644.5 RWHP, 615.7 RWTQ
kinneybell
Mileage: About 18,687 miles , Clear title, For sale by owner! Location: Lewisville, TX
Features
Body type: Coupe, Engine: 8 Cylinder, Exterior color: Silver, Interior color: Black, Transmission: Manual, Fuel type: Gasoline , Leather seats, CD player, Anti-lock brakes, Driver airbag, Passenger airbag, Cruise control, Power locks, Power seat, Power windows, Air conditioning
VEHICLE'S CONDITION
Appearance: Excellent, like new condition, no scratches, very well maintained, great paint job, never been smoked in, no door dings, garage kept, never seen rain or snow,
Maintenance: Frequent oil changes, premium gasoline used, new fuel filter changed 400 miles ago, new spark plugs, changed oil and kinney bell 200 miles ago, always used Mobil One full synthetic with WIX or K&N oil filter
Special features: Professionally built, Boost gauge, K&N air intake, FR500 rims, new Nitto NT55R2 Extreme R tires 305/35/18, adjustable clutch cable billit quardrants, 644.5 RWHP, 615.7 RW TORQUE, -- pleas look at last picture to see the DYNO CHART
***UPGRADES DONE
Built by: HPP MOTORSPORTS
Stroker shortblock: NEW COBRA block, New steel stroker crank, Manley H-beam rods, sephirical dish .020 over JE pistons and rings,Clevite race earings, ARP main studs, machine block, balance rotating assembly, and professionally assembled shortblock
5 angle valve job, ARP head studs, HP blower cams, Gasket kit: front & rear seals, front cover gaskets, valve cover, oil pan, intake, headers, head gaskets, Head cooling mod, Upgraded radiator, 160* thermostat, Kooks long tube headers and offroad X-pipe (all stainless), Magnaflow catback (stainless steel), LFP reservoir, 60lbs injectors and adapter harnesses, Ram 900 series dual friction clutch kit (disc, pressure plate and throw out bearing), Fine spline input shaft with shim kit, Redline D-4 synthetic trans. Fluid, Fluids: oils, filter and coolant,IRS brace, Oil separator with fittings, Windage tray, Aluminium flywheel, Torco, Extra pulley, Kenne Belle 2.2L ,Accufab throttlebody, Water wetter, Spark plugs, MM Full length subframe connectore, Shop supplies, Dynotune using SCT chip W/ (3 Custom tunes)
Serious buyer only—more photos upon request!!
Plenty of cobra's with the same mods for about $22k. I just sold a fully built Saleen and took a big hit. I would offer you $22k if your willing. If not, good luck with sale and the car looks good from the pics.
