You just can't get enough. I had a 2002 Mustang GT that I traded in on the purchase of 2004 SVT Cobra. All I can say is WOW! The only issue I have is that I have a bad vibration in the front end when it is only cold. The steering wheel will shake left to right. After a few minutes on the highway, the problem goes away.I am not sure what is causing the problem. It does not appear to be a warped brake rotor as I do not experience any pulsation in the brake peddel or steering when the brakes are applied. I am starting to suspect one of the front tires. Before I take it to the dealer, I would like to know if anyone else has experienced a similar problem and what the solution was for the fix.
Any help is appreciated.
ygf2002
2004 SVT Cobra - 400 miles
ygf2002
and my right rear was slowly losing presure.
