2004 Wheel Hop
well the title says it all, basically im looking for the solution or at least some things to strengthen the IRS. I was looking at the Kenny Brown Extreme Matrix, but is that enough? Im guessing the bushings should be replaced as well :shrug:
If you plan on getting bushing give this guy a [email protected] can give you what Maximum Motorsports has but at a greatly reduced price. You will still need to order the IRS Subframe bushings from MM as he does not make them. Order the Steeda subrame brace ($25) and put your rear tires @ 28-30 psi.
