Exhaust 2005 Ford Mustang V6 noise from pressing gas pedal
zack2001
Lansing, MI
Marked it as exhaust because it sounds like a potential exhaust leak.
Link to audio clip here (sorry if it's low quality, I recorded it with my phone): View: https://drive.google.com/file/d/1s__XTIqouKyzkKAnGKQPrpDSD-09en8c/view?usp=drivesdk
It doesn't happen when accelerating at stop lights. After getting up to the speed limit, it happens only when I keep my foot in the same spot with light pressure on the gas pedal. Applying more pressure on the gas pedal or letting go of the gas pedal makes the noise stop.
If this is also necessary, the exhaust is aftermarket. It was in the car before I bought it from a private seller, so I'm not sure which one it is.
Thanks for your time.
  • Sponsors(?)
mathews175
10
71006
Sounds like just a bunch of drone noise because you have aftermarket exhausts on a V6. My buddy had the same thing on his '14 V6 and I traded him my stock GT mufflers and he gave me his flowmasters and it worked out just fine.
zack2001
Lansing, MI
It's really annoying, is it possible to make the noise stop?
mathews175
10
71006
Take it to your mechanic and ask him to check and see. Personally it just sounds like drone noise to me and the only way to fix that is to knock down how loud your exhausts are by getting different ones. what kind are on it right now?
zack2001
Lansing, MI
I'm not sure, but they're definitely not dualies. I also want to mention the sound comes from the front of the car, not the pipes, so could it be the manifold?
mathews175
10
71006
read this I still personally think that its drone noise and you nead to change your exhaust systems if you want it to stop rattling something upfront. Basically the frequency that your exhaust is making could very well be rattling your manifold. and guessing that you drive like a normal person in the city the constant hold of the pedal (appx 2000 RPM) can very well make that drone noise rattle the front of your car.
mathews175
10
71006
But before you change them definitely ask your mechanic if he would do a free diagnostic to see if there is a leak if you feel the need to.:)
wicked93gs
1,057
146
93
Nashville TN
Could be anything from a rattling exhaust to a failing stepper motor on a throttle body. One of those things that is just about impossible to diagnose from a sound clip.
Reactions: mathews175
