2005 Technical Service Bulletins (TSB)
MRaburn
Founder
Admin Dude
334
174
Auburn, AL
Below you will find a link to current 2005 Mustang Technical Service Bulletins.
05-14-4
· WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-10-19
· INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
05-9-18
· DISCHARGED BATTERY - CHARGING SERVICE TIPS
05-9-14
· CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-11
· FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
05-9-3
· INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-8-8
· GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 1/15/2005
05-8-6
· EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-7-3
· AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
05-6-15
· AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
05-4-8
· FUEL FILL SLOW, OR DIFFICULT TO FILL
05-3-1
· MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-22
· MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-26-16
· WELD BONDING PROCEDURE
04-24-20
· LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
04-24-14
· GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
· REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-16-1
· ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
04-14-7
· SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
04-9-6
· BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
DOWNLOAD HERE
http://www.stangnet.com/2005tsb/2005tsbs.zip
afixer said:
here is the axel whine TSB
cheers Tom
sorry i needed to clear some space . its back
Hey Tom! Thanks a lot. Took the Service Manager for a drive the other day and he agrees. The noise is a bit too much to deal with so they were going to replace the rear end. It still may be the pinion gear but with this TSB, they may have other options now. Thanks again!
