2006 mustang gt
Quwn05
Atlanta
I have a 2006 mustang gt 115k miles I just got it runs and drive fine for 3 days I put a bigger battery in it to drive it off the Trailer drove it around the block Park it now all it does now is turn over no start....has gas has spark idk what to do anymore I got $4500 in this car somebody help me plz
Maybe spray some starting fluid in the throttle body while someone is cranking. If it catches, it would be a fuel problem. If it still doesn't catch, it would be a spark problem. If fuel, check fuses, inertia switch (if it has one), relay, filter and pump. If a spark problem, check crank position sensor and maybe cam position sensor. Does it ever sound like it is trying to catch? Auto or Stick? Have you tried to pull codes?
Reactions: Kitsune187
