2010, 4.0 no crank no start
htmlngnstrt
CA
Just bought the 2010 Mustang change the plug wires and a new battery now it won’t crank won’t start. I don’t know if it’s locked out on a patch or anti-theft I don’t know what’s wrong with it. Can you help please be much appreciated. Thanks.
Assuming it started/ran fine prior to changing the batter and plug wires? Does it click when you try to turn on the car? or like literally nothing happens?
Change the starter solenoid and/or ensure that everything was put back together correctly.
The solenoid on your car is the round cylinder piggy-back on the starter. The [relay] in your car, I think is mounted nearby the starter or is mixed in with the under-hood fuse panel.
If the relay is clicking but the starter is not starting then the solenoid is bad or wired wrong.
