2011-12 Mustang V6 BBK 73mm Throttle Body Available At Brothers Performance!
BBK-1822 - 2011-12 Mustang V6 BBK 73mm Throttle Body
Bolt On Horesepower and Increased Throttle Response with these direct fit replacement units for your application.
Best of all they are a true bolt on and no tune is required, add a cold air kit for even more horsepower and torque.
As with ALL BBK Performance Power+Plus Series throttle bodies they are CNC machined from high quality 356 aluminum castings to ensure perfect OEM quality and fit every time. They also feature OEM die stamped throttle linkages, double sealed bearings, o ringed throttle shafts and new electronics and controlled injection molded plastic gear assemblies for the new modern drive by wire applications, make BBK throttle bodies number one in performance and quality.
BBK spent hundreds of hours, researching, developing, and experimenting with late model Ford electronic throttle bodies. As a result, we have gathered the extensive knowledge on the function of these sophisticated parts that it takes to produce the best possible product.
All throttle bodies are direct replacements and include detailed installation instructions on installation.
To order, call 1-800-486-2681 or go to www.brothersperformance.com
Check out the video below to see how easy it is to install!!
