Expired 70mm Throttle Body
Jered
DESCRIPTION
More Power. Increase the airflow in to your 4.6L engine for improved throttle response and more horsepower with a SR Performance 70mm Throttle Body.
Precision Crafted. This SR Performance Throttle Body is made from a permanent mold casting of 356 aluminum to produce a higher quality casting than conventional sand molds, which reduces porosity for an improved finish.
Application. The SR Performance 70mm Polished Throttle Body is designed to be a direct fit replacement on the 1996 to 2004 4.6L SOHC GT Mustang. 70mm throttle bodies work great on stock or mildly modified GT mustangs.
Opened but not used; asking $130.00
Also comes with BWD THROTTLE POSITION SENSOR!
Louisville Ky
