235/60 r15 fit front of 69 coupe???
  • Thread starter Thread starter BrownPSU78
  • Start date Start date Dec 28, 2007
BrownPSU78
129
Dec 28, 2007
  • Dec 28, 2007
So far i have not done any suspension work yet however i hope to do the drop springs in the front eventually however the front springs are original and probably saggy...so will the 235/60 r15s fit on the front end?
Thank you for your time...
D
D.Hearne
11,730
south louisiana
Dec 28, 2007
  • Dec 28, 2007
They will for sure with the stock steel wheels and stock ride height springs, they should with a 1" drop. I ran this size on my 67 Big block fastback with Dodge Police car wheels(15x8" with a 4" backspace), and as I recall there was plenty of room.
P
palerider94
573
  • Dec 29, 2007
nice chart for 69/70
http://www.dodgestang.com/Tire Fitment Guide 69-70.pdf
BrownPSU78
129
Dec 30, 2007
  • Dec 30, 2007
so thats a yes???
bdepedro
362
Outer Banks, NC
Jan 1, 2008
  • Jan 1, 2008
BrownPSU78 said:
so thats a yes???
That's a definite yes. I have a '70 but the front fenders are the same. That is the exact tire I run on my front w/ 1" lowered springs and have too much room. I'm planning on cutting my springs to bring the front down another inch. You should have absolutely no problem with a stock (even saggy) front suspension.
bnickel
5,640
lubbock, texas
Jan 2, 2008
  • Jan 2, 2008
yes a 235/60-15 will work just fine, basically the same size as an f-60-15 which was stock on boss 302's. you just have to make sure you have the right backspace rim, if it's wrong the tires will rub the fender lip and/or the front valance. also if you have too much positive camber you could rub on the front valance, a good alignment will take care of that though.
chepsk8
2,203
Easton, PA
Jan 3, 2008
  • Jan 3, 2008
I had them on the 69 Mach with the Magnums. Filled up the wheelwell nicely, and did not rub. I would be wary of dropping the ride height.
bdepedro
362
Outer Banks, NC
Jan 3, 2008
  • Jan 3, 2008
Depending upon the bs I would think he would be fine with a 1" drop at least. If his suspension is original stock he may be at that height right now. When I upgraded my suspension I went with 1" lower springs and didn't see a major drop but I still have plenty of clearance to drop another ".
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
