24# injector/Mass Air question....
  • Thread starter Thread starter Vinnietbird
  • Start date Start date Jan 24, 2009
Vinnietbird
584
  • Jan 24, 2009
Will a Mark VIII mass air sensor work with the 5.0?I have two of the meters and sensors,and a set of 24# injectors.I have an A9P running my car now.I also have the 70mm Mass Air meter.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 24, 2009
  • Jan 24, 2009
In order to use 24lb injectors you will need an aftermarket MAF or a custom dyno tune/chip. There is no Ford OEM MAF that is deigned to work with 24 lb injectors. All Ford computers are programmed for the injector size for a specific engine in their firmware program.
Vinnietbird
584
  • Jan 24, 2009
I'll start looking for an aftermarket MAF then.easy.Thanks for the info.
vristang
4,933
101
124
Seattle
Jan 25, 2009
  • Jan 25, 2009
An X3Z ecu may still be an option for the 24's and ??? MAF meter....
Post all the numbers on the MAF meter you have.
jwzg
237
Prattville, AL
Jan 25, 2009
  • Jan 25, 2009
The only way you can run 24's with stock Ford components is to have the X3Z computer and 70mm MAF housing that came on the Cobra/Thunderbird SC as the transfer function of that MAF is matched to those respective computers.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jan 25, 2009
  • Jan 25, 2009
Custon dyno tube > aftermarket MAF
Vinnietbird
584
  • Jan 25, 2009
That figures.I just sold my Cobra computer.I'll start looking around for another one.
vristang
4,933
101
124
Seattle
Jan 25, 2009
  • Jan 25, 2009
Why not post the numbers for the MAF meter you have first, then you can decide if the X3Z is appropriate for you.
Depending on what MAF you have, it may be more cost effective to do different things...
You need to confirm the parts that you currently have BEFORE buying more parts...
jason
Vinnietbird
584
  • Jan 25, 2009
I'll get them posted as soon as I can.The MAF meter I have now is a 70mm part,with a Mustang GT sensor.Anyway,numbers on the way soon.
Maryland Stang
1,656
30
39
Greenville, NC
Jan 26, 2009
#10
  • Jan 26, 2009
  • #10
Don't bother. Putting an A9L/P MAF sensor into another housing renders the whole thing useless as far as trying to match it to a computer.
Air doesn't flow through sensor housings the same way in any two given housings. Since it doesn't flow the same way you need specific sensors to properly read the amount of air going through the housing.
Some of the things that affect air flow through the housings are size and shape of the inside of the housing and the size of the orfice that the wire is suspended in. Even the placement of the air filter can affect the meter readings. That's why some people clock their meters in an attempt to correct an issue.
My advice: Ditch the MAF that you have now and start over.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
